xerox 700 077-220 error
  • lion_heart
    • Jun 2014
    • 174
    Good day, getting this 077-220 pre-reg jam, would print about 10 sheets, then jam at pre point. there is a loud grinding noise seem like every time it tries to either pick up sheet or send it through the pre-reg. Noise happens on every sheet. Changed the whole registration transport assembly, same issue. wondering if the ONLY option can be the registration transport drive assembly motor or am I overlooking something? any assistance would be greatly appreciated. thanks
  • lion_heart
    • Jun 2014
    • 174
    Re: xerox 700 077-220 error
    Giving an update. seems as if it has something to do with the duplexing, When I run a job at 300dpi and face up and not duplex seems to work fine. any suggestions? thanks
    • adriansto
      • 2387
      Yes you need to inspect the components from preregistration motor assy 7K98040.
      Worn gears, coupler, etc
