Color test
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Color test
    Hi!
    I would be very grateful for the simple instructions.Not familiar with Xerox.
    I need to evaluate the machine and I would like to print a color test pattern to check the quality of the printing. I do not have the ability to print from pc. I need some kind of color report from memory.
    Thanks!
  • xcopytech
    • Aug 2006
    • 1794
    Re: Color test
    Maybe we can help you if you tell us for which machine you need test print. (Dc250/252, dcp700, c550, etc)
      • 23008
      Re: Color test
      Does it print from USB? How about this:
      • zoraldinho
        • Mar 2008
        • 5015
        Re: Color test
        Thanks David!
        I have in mind test print from service mode like Canon PG-5,PG-10.....
        It's WorkCentre 24.
        • zoraldinho
          • Mar 2008
          • 5015
          Re: Color test
          Sorry.My bad. It's WorkCentre 24.
          I mentioned the model in the previous thread but subconsciously I wrote the last word print.
          Yesterday, I spent 30 minutes setting up default scan settings but always PDF file jump back to JPG.Entering admin mode with a few ones and set in "scan defaut" but no go.
          Any hints?
          Thanks!
          • xcopytech
            • Aug 2006
            • 1794
            Re: Color test
            For wc24 you will need xerox pws and wc24 diagnostig tool to make test prints.
            • adriansto
              • 2387
              Re: Color test
              Any hints?
              Thanks!
              Also there are several machine software versions.
              May be some version dont accept pdf scanning.
              I think I have pws tool for m24 machine but I'm not sure about this.
              • zoraldinho
                • Mar 2008
                • 5015
                Re: Color test
                Thanks Adrian!
                I doubt about the software, because for each document, the pdf is working ok.It won't stay dafault.
