WC 5845 ... white screen Help Plzzz
  • papoudaii
    • Feb 2018
    • 7
    [Dead] WC 5845 ... white screen Help Plzzz
    Hi gys . someone hlp me plz
    ih hev the XEROX WC 5845 ferstly she stuck on the start screen
    like that
    i tryd restart ti ...no result
    end i formatd the SD card ((by mistake))
    28548205_1697666786959805_2045244331_o.jpg28554684_1697666836959800_1053195719_o(1).jpg
    now when I turn on the machine . she stuck "white screen"
    end i trayd to boot it .. no result
    someone send me en "ISO" for the SDcard or any other solution
  • adriansto
    • 2384
    Re: WC 5845 ... white screen Help Plzzz
    Put back the sd card and watch the error that appear on sbc pwb display - back side of the scanner
    • papoudaii
      • Feb 2018
      • 7
      • adriansto
        • 2384
        Originally posted by papoudaii
        [ATTACH=CONFIG]39008[/ATTACH][ATTACH=CONFIG]39009[/ATTACH]
        8 error code indicate you have defective memory module on SBC pwb.
        But also your sd card is corrupted so purchase a new sd card try to reload software using usb memory stick and if the 8 error is still there then replace the memory module.
        • markuss100
          • Feb 2018
          • 16
          you could re-install a firmware by using a pin drive insert it from the back and find the firmware on Business Services and Digital Printing Solutions โ€“ Xerox
          -you need a pin drive on that pen drive creat a folder name it altboot
          -place the firmware you dawnloaded on the altboot folder
          -then create a text document empty just name it FORCE_UPGRADE use caps word
          -turn off your machine then insert your pen drive then turn it on
          -at that point it should appear software upgrade in a moments
          if the screen still white you should order a new sd card
          • papoudaii
            • Feb 2018
            • 7
            i mounted a new SD card and new HDD and new memory module
            i usid a pin drive insert it from the back "altboot folder & FORCED_UGRADE"
            she still a screen white & the 8 error
            • adriansto
              • 2384
              The new SD card is from Xerox ?
              • papoudaii
                • Feb 2018
                • 7
                its a standard SD
                • adriansto
                  • 2384
                  Nice.
                  You can use it into old photocamera.
                  On that sd card must be some instructions.
                  Purchase it from Xerox
                  • papoudaii
                    • Feb 2018
                    • 7
                    any other solution !!???
                    • papoudaii
                      • Feb 2018
                      • 7
                      any other solution !! Guys
                      • mkdirs
                        • Oct 2014
                        • 177
                        you delete the NVM Files
                        you need to copy a new nvm files to the sd
                        I don't have the files sory
                        Xerotk.com
                        xerox copier technician
                        • papoudaii
                          • Feb 2018
                          • 7
                          Where i find the nvm files !!?,
                          • Richard.Xerox
                            • Jun 2015
                            • 73
                            You need to order up a new SD card from you Xerox parts supplier, also memory module.
                            Install both and wait 15 minutes, machine takes a while to initialize the new SD card.
                            After that if not booting perform an Altboot to reload the firmware.
                            It's that simple.
                            No-one can give you the files, you need to order the proper Xerox SD card.
