XEROX 7655 Comunication failure
  • Edib Vektor
    Everything can be solved
    • 15
    Hello. I occure problem with Xerox WorkCentre 7655. The machine show me this message "Comunication Failure
    After restart, machine ask for initialization, and after it reset counter to 0.
    Also, after close inspection, I figure out that machine have error 03-355
    (CCM POST failure NVM battery may be dead). I just dont know witch battery i need to replace, Jellow one or..?
    Pleas help, cheers!
  • adriansto
    • 2387
    Re: XEROX 7655 Comunication failure
    Yes you need to replace yellow battery and also you will need pws tool for the machine.
    • Edib Vektor
      • 15
      Than you for information. I replace NVM battery, but I dont have PWS diagnostic for this machine.
      After i replace battery, the problems start, the machine print B&W copies just fine, but color are big problem, it have RGB stripes
      But when i print some of color test patterns, they are okey.
      28576237_10208950403792461_3131282560399704064_n.jpg28685451_10208950407792561_3730737725792321536_n.jpg
      Also i have 3x list for NVM valuse, can re enetering it solve this problem?
