color misregistrations xerox 700
  • Mukasa
    • May 2015
    • 178
    [CQ] color misregistrations xerox 700
    A slight color yellow mis-registration , When you run the MOB sensors test displays NG , even the Regicon is NG
    I have tried to clean the MOB sensors cleaned the ROS and swamped the drums still no change.
    What can i do to pass the test?
    Godfrey
  • adriansto
    • 2386
    Re: color misregistrations xerox 700
    What about IBT ?
    The sensors read from it.
    • knightfall
      • Jul 2006
      • 633
      Godfrey
      it might be the yellow drum motor failing try switching the yellow drum motor with the magenta or cyan if the registration moves with the drum motor then replace that motor.
      Get your facts first, and then you can distort them as much as you please.
