How can i make xerox 5755 & 5855 work without fuser & drum chips
Re: How can i make xerox 5755 & 5855 work without fuser & drum chips
you need Code generator to change service plan to "C" (Aftermarket -System will accept non-Xerox and OEM suppliedxerographic module with no CRUM) BUT... you still need to install chips, because it won't work without chipsComment
doesn't matter about workarounds.Comment
Yes you can and you can do that without chip
But the fuser cleaner will not rounding to clean
If thats ok send to me the xerox S/N
And i will send to you the codeXerotk.com
xerox copier technicianComment
Raja45
We have already tried the same in 5755 , We found that only Drum cleaning motor is not working but Fuser motor is working share your viewsComment
Xerotk.com
I take it your not giving up on this one. Ok if your car didn't have the electronics from ignition to motor your car wouldn't start....correct. so your waiting valuable time of these people on here to tell you otherwise. If no chip is on those units the machine does not recognize them being in the machine. Try it. Remove chip and put in. If you want to waste money and pay someone who will by all means.
Simply it can't be done all communications run off the chip. If the internet is still around when you finally figure it out let us know as you are in a Xerox forumComment
we also tried drum cleaning motor not working but fuser web motor working fine!Comment
