xerox dc242 problem with transparency
  • Enzo
    • Jul 2009
    • 413
    Hello friends. I have a printing problem with xerox dc242. see the attached file. I have a problem with transparency. transparency is almost invisible on the file, while in print it is very clear. the same file, on other machines also xerox I do not have this problem. How can I solve it? I did the calibration but I did not solve it
  • xcopytech
    • Aug 2006
    • 1794
    Re: xerox dc242 problem with transparency
    In max setup you can adjust colors.
    • adriansto
      • 2388
      [ATTACH=CONFIG]39201[/ATTACH]
      Transfer problem.
      You need to play with 2nd btr curent transfer.
      • Enzo
        • Jul 2009
        • 413
        I tried to do the max setup and to change the 2nd btr. the problem is still there. the quality of the color has improved but that problem is still there. can I change some specific settings? maybe using a patch to correct the watermark?
        • xcopytech
          • Aug 2006
          • 1794
          What did you adjust in max setup?
          • Enzo
            • Jul 2009
            • 413
            "atc sensor" and "auto gradation". other commands I do not know in the details
            • xcopytech
              • Aug 2006
              • 1794
              Atc sensor need to be adjusted only if you replace developer housing.
              Perform max setup adjustment from service manual and you will be able to get proper print quality.
              Adj 9.1 to 9.5
              • Iowatech
                Not a service manager
                • 3930
                This might be the stupidest thing ever, but what type of transparency are you using? Some transparencies are not fit to be used in this application, and they will cause issues like this.
                Sorry if this was a waste of time.
                • Enzo
                  • Jul 2009
                  • 413
                  Adj 9.1 to 9.5
                  Which setting should I check?
                  • Enzo
                    • Jul 2009
                    • 413
                    Maybe I wrote the title badly. I have problems with images like watermark. When I set some images like the one in the picture in my first post, they are much more visible in print. On other machines, the same file is printed correctly.
                    • Enzo
                      • Jul 2009
                      • 413
                      Hello friends. I always have this problem on xerox dc242. as you can see from the attached image, the print has panels behind each image. why? It is not the first time that such a thing happens to me. thank you
                      • xcopytech
                        • Aug 2006
                        • 1794
                        Corel or pdf file?
                        Bustled or standalone fiery?
                        Installed all patches from efi site?
                        • Enzo
                          • Jul 2009
                          • 413
                          Corel or pdf file?
                          Well!
                          1- pdf file
                          2- fiery exp260
                          3- patch installed: 1-SI2JK 1-U8E58 1-Z4E66
