help
  • etsmultan
    • Apr 2007
    • 131
    help
    can any body tell me how can i use my xerox pro555.when we switched on copier it shows printing and network controller is not availaible.pls tell me about this issue also send me service book.my id is etc_new@hotmal.com
  • xcopytech
    • Aug 2006
    • 1792
    you have to reload system software for network controller.
    you need xerox pws and altboot software for dc 535 to do that.
    maybe you will have to replace hdd too.
    • etsmultan
      • Apr 2007
      • 131
      i had open cpu cables from copier but problem remains same pls help me
      • xcopytech
        • Aug 2006
        • 1792
        post which error code you have
        if you just disconnect cable machine will still search network controller.
        you have to change some NVM values, so machine will become a copier.
        but think that you have some other problem, enter in diagnostic mode and see in fault history which fault code you have.
        or call some xerox tech
        br
