061-310
  • almerico
    • Oct 2012
    • 58
    [Error Code] 061-310
    on my docucolor 240 I changed the ROM which was damaged, but when it came on I got the error code 061-310. the DADF works, the tray 5 works. Only the belt cycle does not. I own PWS. thank you all.
  • xtrain
    • Dec 2012
    • 233
    Re: 061-310
    The 061-310 RAP says to check connectors on the (Y/M) ROS, and the MCU PWB. If they are ok, replace (Y/M) ROS, 062K17306, or MCU PWB, 960K18011.
    • almerico
      • Oct 2012
      • 58
      Re: 061-310
      before changing the XEROX DC 240 ROM 160K99820 did not give me this problem. is it not possible to reset these types of errors or to see through PWS if you finish everything fine before buying a new Ros or connectors? thank you
      • xcopytech
        • Aug 2006
        • 1757
        Re: 061-310
        What software level is on ROM and what level is on machine.
        • almerico
          • Oct 2012
          • 58
          Re: 061-310
          Rom 1.231.5. how can I see that of the printer?
          the screen always comes out in English even if the change at each power-up and the copy and off button
          • copytech,mike
            CopyTech,MIKE
            • Jun 2014
            • 236
            Re: 061-310
            Not sure why the ROM would have anything to do with 061-310 bad laser unit. Did you ever fix this machine?
