Xerox 6204 Wide Format - Unable to connect to Web Interface - help me please !!!!
  • Gh-jim
    • May 2018
    • 7
    Hello, I have a problem, the page 13.240.20.38 does not appear, I have a Xerox 6204 with external unit, a year ago and after a drop in voltage, the controller is HS and I had another unit other than the dell and it worked all that time (a year). A week ago, the same thing happened, the controller is HS (motherboard too) despite the presence of an inverter and voltage regulator, I tried on several units but nothing works, the ping works but I can not access to it, I followed the procedure but nothing, local Xerox technicians no idea of ​​the problem, I have unanswered questions:
    - Is there a particular hardware configuration of the controller (ram, processor, network......)
    - Why do not I have the word "successful" at the end of installation?
    - Is there a special formatting of the hard disk?
    - Does the installation have to be done with the original cd not a copy (maybe a copyright) (I have the original too)
    - Is there a manual service of the controller?
    help me please !!!!
    http://forum.support.xerox.com/t5/Printing/Xerox-6204-Wide-Format-Unable-to-connect-to-Web-Interface-help/m-p/215584
  • xcopytech
    • Aug 2006
    • 1783
    Re: Xerox 6204 Wide Format - Unable to connect to Web Interface - help me please !!!!
    What did you try to install?
    Os recovery/install cd or just freeflow controller software for 6204?
    • Gh-jim
      • May 2018
      • 7
      the original controller of the machine is dead, I replacing it with another normal unit and it has to walk a year, then it is dead too, I wanted to replace it again with another, I install the system with the OS recovery / install cd, the installation is done but there is not the mention "successful" at the end, I ping the ip address it responds, but the web page does not open !!!, it is for that I ask all the questions at the top.
      I am lost, and I do not understand what is the problem ???
      • xcopytech
        • Aug 2006
        • 1783
        Perform media check.
        Maybe your cd is damaged.
        Maybe you can try with newer version.
        Latest os instal version is 5.2
        • Gh-jim
          • May 2018
          • 7
          I have the original CD and I burned another one at low speed, and nothing
          a link for downloading the new version?
          • xcopytech
            • Aug 2006
            • 1783
            Xerox tech can test CD from diagnostic.
            Xerox tech can download latest OS from xerox gsn site.
            • Gh-jim
              • May 2018
              • 7
              the local Xerox technician really does not feel competent, can not rely on them
              please another proposal !!!
              • xcopytech
                • Aug 2006
                • 1783
                Do you know what was your original controller serial number.
                • Gh-jim
                  • May 2018
                  • 7
                  The Service Tag 7650G5J
                  • Mukasa
                    • May 2015
                    • 178
                    Hay Brother lets go slow,
                    lets go step by step
                    do you have the Os recovery/install cd
                    Yes or No
                    • xcopytech
                      • Aug 2006
                      • 1783
                      Check attachment
                      • Gh-jim
                        • May 2018
                        • 7
                        is more than to find a motherboard with the good Part Numbe for the cd that I have (v4.4), I'll keep you informed of the evolution of things, if you have other necessary information I am a taker, thank you very much for your help and great greetings
                        • Gh-jim
                          • May 2018
                          • 7
                          Yes or No
                          yes I have it, I posted the picture of it in this link
                          • xcopytech
                            • Aug 2006
                            • 1783
                            Latest controller is DA0 (dell 790) with I3 and dell 7010 with I5 processor.
                            For them you need OS v4.5 or higher.
                            Maybe to try with some older PC with dual core or celeron processor.
                            • Mukasa
                              • May 2015
                              • 178
                              [QUOTE=Gh-jim;605138]Hello, I have a problem, the page 13.240.20.38 does not appear, I have a Xerox 6204 with external unit, a year ago and after a drop in voltage, the controller is HS and I had another unit other than the dell and it worked all that time (a year). A week ago, the same thing happened, the controller is HS (motherboard too) despite the presence of an inverter and voltage regulator, I tried on several units but nothing works, the ping works but I can not access to it, I followed the procedure but nothing, local Xerox technicians no idea of ​​the problem, I have unanswered questions:
                              help me please !!!!
                              Hello ,
                              After installing the OS CD , that controller came with other CDs with feature KEYs to activate OS, Print, Scan, Copy through XES xerox web site.
                              you can contact me on email : mukasa_godfrey@yahoo.co.uk
