Banding in xerox color c60
  • abdou
    • 39
    [CQ] Banding in xerox color c60
    Hi everyone I have a probleme with my machine xerox c60 when I print in black color I see a repeating bands of 1 mm I changed the developer assy, the developer drive, ROS, PHotoreceptor black, flat cable of the ROS but the probleme not fixed this probleme is occured in the installation of the machine, Can enyone help me please!!!!
    Re: Banding in xerox color c60
    belt? or fuser?
    • exCSER
      • Mar 2009
      • 98
      If the problem only shows in black and not any other single color, I would suspect drive to the black P/R since you already changed the drive to the black developer.
      • abdou
        • 39
        The problem in the black color only I changed drive to the black P/R but the problem is not resolved thanks you for reponse
        • xcopytech
          • Aug 2006
          • 1794
          Black developer hvps.
          • knightfall
            • Jul 2006
            • 633
            would be easier with a picture.
            are you printing or copying that creates the black?
            did you try test print in each color (C,M,Y,B, and B in FC)?
            it could be a process black and one of the color is creating the band.
            Get your facts first, and then you can distort them as much as you please.
            • abdou
              • 39
              I changed the hvps for black developper housing bias but the same problem the banding is in both copy and print mode other color c m y is fine the probleme in black copy only I repeat I changed the developper module, ros module, module drive for black, photoreceptor, hvps, the same probleme
                ANY time you have Print or Copy Quality issues please post a picture of the printed problem... also indicate direction of paper travel.
                  all that and did you check the transfer belt?
