Just bought a DoA Phaser 7800 GX
  • rrutter81
    • May 2018
    • 28
    [Dead] Just bought a DoA Phaser 7800 GX
    Hey all,
    I'm new to the site and figured I'd ask for some recommendations on my dilemma.
    I recently purchased a Phaser 7800 Gx online and was told it was guaranteed to work on arrival. The guy I purchased it from was transparent and told me that the hard drive was loose and I would need to secure it better somehow, but the machine prints if it is plugged in. For the price (1500) i was good with it and told him it was fine.
    So i receive the printer, and try to boot it up and get a no hard drive error with a blue screen. Ok. So i slide out the board. plug it in. Now it reads "Internal Communication Failure. Please call for assistance".
    Not very helpful.
    So i take off the shroud, and notice a blinking green led. It pulses for a few and then pauses and resumes the same error pattern. I had no idea xerox was so defensive of their service manuals but I came across mine with a little digging.
    Supposedly this machine can boot without a hard drive. This goes contradictory to what the guy said when he sold it to me.
    The 6 blinks and pause according to the service manual states that the control panel cannot communicate with the main board. I find it weird the control panel would be faulty if it gave me blue screen errors about not having a hard drive followed by a generic "internal communication failure". Where it fails at is upon the FPGA boot up checks yet the FPGA is not indicated as a problem or else the led would have blinked 3 times.
    So am i wrong to think that the control panel needs replacing even though the screen displayed a couple blue screen errors? Could it be the socket on the board where the control panel mates with it?
    Any advice on this model would be appreciated.
    -Russ
  • Flash
    • 378
    Re: Just bought a DoA Phaser 7800 GX
    I would start with an altboot with the latest firmware.
    • rrutter81
      • May 2018
      • 28
      It doesnt even get to that point.
      no fans kick on at all. Just the led health indicator blinking 6 times on the main board.
      • rockdude
        • Feb 2011
        • 257
        Sounds like an LVPS went bad.
        There was also a bulletin out, about a blank display (Dead Machine) due to a bad SD card.
        Change SD card and then perform ALTBOOT with latest firmware.
        Not sure which applies to you
        • shinchan
          • May 2011
          • 195
          Try unplugging the RAM. Clean the gold plated contact of the RAM using an eraser. Good luck
            no ALTBOOT is a firmware loading procedure.
            • rrutter81
              • May 2018
              • 28
              Yes i have the usb stick.
              The issue is it fails the Power On Self Test (POST) sequence.
              No energy star logo, no fans, no nothing.
              • rrutter81
                • May 2018
                • 28
                Yea i checked the sdcard (i cant read it due to the partition being wrong?) i chalked it up as an encrypted sd card, reseated the ram (contacts are clean), reseated the hard disk. Nothing.
                • rrutter81
                  • May 2018
                  • 28
                  This doesnt quite explain the 6 blinks on the mainboard led health indicator. Also it isnt a blank display.
                  Not sure if i should trust the control panel cant communicate or if it is a board problem.
                  SD Card might be bad but why would it send me down a rabbit hole?
                  Thanks guys for your help
                    LOOK at the manual...
                    ALTBOOT is for loading firmware when the machine doesn't go to the ready screen.
                    • rrutter81
                      • May 2018
                      • 28
                      Im telling you. The FPGA is detecting a problem with the hardware before the thing even goes to boot.
                      I tried the ALTBOOT - forced upgrade method. It does not work. It's like if you tore your ram out and tried to ALTBOOT it. I still receive the blue screen of death. I actually had to open the shroud up to see the LED health indicator light.
                      I assume it is failing at step 4. I would assume the SD CARD, however, I still get the led blinking error.
                      • rockdude
                        • Feb 2011
                        • 257
                        I would "CHANGE" the SD Card.
                        This is a "KNOWN" problem with this machine!
                        Part No. 160E04222 List Price $63.00 + $15.00 shipping
                        Good Luck
                        • rrutter81
                          • May 2018
                          • 28
                          Good Luck
                          thanks for the advice. its top on my list!
                          • rrutter81
                            • May 2018
                            • 28
                            Just an update.
                            I replaced the sd card and have the same 6 blink led error. I had a hunch that wasn't the problem as the led blinking indicator shouldn't be giving false positives. I at least have 3 copies of this sd card so I don't have to pay the premium for it anymore.
                            If you read this, just do a sector by sector copy of the sd card and you won't have to pay the outrageous prices of a simple sd card.
                            I will be ordering a replacement control panel (which I believe is the issue) and see if that solves it.
                            • rrutter81
                              • May 2018
                              • 28
                              Well.
                              I replaced the control panel and still have an internal communication failure. LED on the mainboard still blinks 6 times and then repeats.
                              I'm kind of at a loss at this point.
                              Maybe the wiring harness is messed up?
                              The receiving board is no good?
                              I figured following the manual would have solved it.
                              Here is a video of what I am working with...
                              xerox 7800 error code on Vimeo
