Xerox WC 5765 error- "adjusting fuser module (R3) temperature"
  • ITHPP
    • Jun 2018
    • 9
    [Error Code] Xerox WC 5765 error- "adjusting fuser module (R3) temperature"
    Hi... I am new at this. I barely understand tech talk.. but here goes..... I recently took on a small printing operation. It is a service for a monthly newsletter and not a business. So anyway... I have a Xerox Workcentre 5765. It keeps giving me a message - "adjusting fuser module (R3) temperature". But the fuser never gets up to temperature. If I pull it out it sure feels like it is hot enough. But it wont ever get in the right temp zone to get past the fault. I tried multiple fusers that I knew were working, including a brand new one. That one lasted about 20,000 pages then the same fault came back up. I tried changing out the contacts in the back of the machine, tried resetting the software. Nothing seems to work. I see a few others have faced this but has anyone found the solution?
  • spyro
    • Jan 2019
    • 10
    Re: Xerox WC 5765 error- "adjusting fuser module (R3) temperature"
    Obviously u got problem after the fuser connector pj100. So check pj100 to pj35 and to pj24, either the power or the temp - lvps or the iot are problematic if the cables r fine.
