xerox 7545 "replace black toner"
  • sujesh
    • Dec 2017
    • 7
    [Misc] xerox 7545 "replace black toner"
    hi,
    i have an xerox 7545 workcentre printer,showing message "replace black toner ".We changed black toner to new one ,tried with working toner from other machiene,cleaning done inside,Crum coupler changed ,firmware updated ,still same error.
    nvi reset also done,one thing happening is after nvi reset,error will not show and supplies toner level also shows and 2 print will be success.Then again it will show error message.
    hoping that someone will help me to resolve this error
    System Software Version:061.121.228.04700
    System Software :061.121.228.04700
    Network Controller:061.128.04720.LL
    User Interface :061.128.01100
    Marking Engine :082.080.000
    Copy Controller :061.128.00900
    Document Feeder :007.010.000
    Finisher :032.052.000
    Fax:
    Copy Controller OS : 061.128.04700
    Network Controller OS: 061.128.04700
    Scanner :030.141.115
    Software Upgrade :120.116.00132
    Machine Upgrades : Enabled
    Last Successful Upgrade: July 9, 2018 6:06:46 A
    Re: xerox 7545 "replace black toner"
    Originally posted by sujesh
    hi,
    Fax:
    what is page count on drums and developers? toner loads to dev unit then drum/belt
    • xcopytech
      • Aug 2006
      • 1793
      Replace dispense pipe assembly.
      094K92391
      • sujesh
        • Dec 2017
        • 7
        Total Impressions 712519
        Black Impressions 186447
        Black Copied Impressions 99574
        Black Printed Impressions 86873
        Color Impressions 526072
        Color Copied Impressions 128241
        Color Printed Impressions 397825
        Internet Fax Impressions 0
        Server Fax Impressions 0
        Large Impressions 78582
        Black Large Impressions 12142
        Color Large Impressions 66440
        Stored Image Printed Impressions 0
        Black Stored Image Printed Impressions 0
        Color Stored Image Printed Impressions 0
        Black Copied Sheets 47853
        Color Copied Sheets 85048
        Black Printed Sheets 46171
        Color Printed Sheets 242352
        Black Copied 2 Sided Sheets 34636
        Color Copied 2 Sided Sheets 60278
        Black Printed 2 Sided Sheets 26535
        Color Printed 2 Sided Sheets 169640
        Black Copied Large Sheets 2591
        Color Copied Large Sheets 6129
        Black Printed Large Sheets 2909
        Color Printed Large Sheets 30083
        *see attached picture
        • sujesh
          • Dec 2017
          • 7
          094K92391
          Hi,let me try as u suggested.
          • Mukasa
            • May 2015
            • 178
            also think of the toner sensor in the Dev box
            • sujesh
              • Dec 2017
              • 7
              hi,
              we changed dispense pipe ,still same error.
              After nv ram reset its printing configuration pages and then after calibration same error occurs.
              • sujesh
                • Dec 2017
                • 7
                new toner installed,same error
                working toner from other printer installed same error.
                crum coupler changed same error
                • sujesh
                  • Dec 2017
                  • 7
                  094K92391
                  hi, we changed dispense pipe ,still same error.After nv ram reset its printing configuration pages and then after calibration same error occurs.
                    not new TONER but the toner density sensor in the DEVELOPMENT UNIT
                    • chubblies
                      • Jun 2011
                      • 154
                      The little gears that drive the toner dispense pipe can hairline crack, either on the actual toner dispense pipe or on the gearbox at the rear of the machine that drives it. Swap the gearbox with one of the other colours and see if the fault follows the gearbox
