Service Manual for xerox 700 series
  • Kwaku01
    • Aug 2018
    • 121
    Hi,
    Please does anyone have, or know where to get a service manual for xerox 700 series? I'm in desperate need of one!
    Tnx
  • adriansto
    • 2387
    Re: Service Manual for xerox 700 series
    Originally posted by Kwaku01
    Hi,
    Tnx
    I have it in edoc format.
    You need pws software (laptop) for use the edoc.
    • Kwaku01
      • Aug 2018
      • 121
      Please do you have any idea where and how to get pws software (laptop)? I'm in desperate need to fix this issue of duplex jamming....""077-130 duplex out sensor on jam"
      • adriansto
        • 2387
        You must check duplex motor, duplex clutch and duplex drive belt.
        I sent you private message - PM
        • Kwaku01
          • Aug 2018
          • 121
          Responded, tnx.
            you have to buy the laptop... depends on where you buy it from it might be loaded with the manual you require.. or ask for that Edoc @ time of purchase.
            if you never have worked with a PWS system... hire a trained Xerox tech
            • Kwaku01
              • Aug 2018
              • 121
              Please where is the "duplex motor, duplex clutch and duplex drive belt" located?
              Found two motors by the duplex unit. One on top and the other
              underneath, not sure which one is the duplex motor. The top
              one has a belt and has some movement when machine is on.
              • ofiexpertos
                • Nov 2012
                • 10
                Hello,
                I need SM for Xerox 700, J75, V80 and V180 my mail for private comercial@ofiexpertos.com
                Thanks.
                • adriansto
                  • 2387
                  All these are available in edoc format.
                  You need pws for use the edocs
                  • ruffsqwad
                    • Jun 2021
                    • 1
                    Helpful advice yet again from Phil B.... Who's a good boy.
