Xerox 560
  • bobcap
    • Feb 2012
    • 15
    Xerox 560
    All of a sudden between print jobs this Xerox 560 went from printing very well to printing very very light.
    No error codes.
    It does the same if it is a file sent via the rip or a copy done from the glass.
    Help
  • Milo Wilson
    • 483
    Re: Xerox 560
    Check the bias connector on the 2nd BTR assy
    • bobcap
      • Feb 2012
      • 15
      Re: Xerox 560
      Where do I find that on this machine?
      • bobcap
        • Feb 2012
        • 15
        Re: Xerox 560
        Seems OK to me?
        • adriansto
          • 2329
          Re: Xerox 560
          Panic stop the machine when copy goes light and check how the image on belt looks.
          If the image on belt is ok the you have transfer problem and check 2ndBTR assy.
          If on belt same faint, light image probably you have problems with High Voltage Power Source and need to check it and it electrical connections or 24 volts from LVPS= Low Voltage ....
