Xerox 7755 error 342-325, 394-322 (machines is not available attempting to recover
  • Bessnet
    • May 2016
    • 5
    Hello Guys,
    Please help me in regards with above mentioned error codes first code is 342-325 then 394-322.
    main motor is not rotation and machines is not rotating as usual, at starting bypas lifts up half and ibt unit lifts and stuck in half.
    i have tried changing
    1. main motor assembly.
    2. black drum motor assembly.
    3. black developer motor assembly.
    4. waste toner assembly.
    5. 2nd btr drawer complete assembly
    6. all drum motor.
    7. mcu pwb board
  • adriansto
    • 2387
    Re: Xerox 7755 error 342-325, 394-322 (machines is not available attempting to recove
    Bad front door interlock switch or 24 volts missing from defective LVPS
    • Matthew1876
      • Jan 2017
      • 25
      Try changing the drive motors for YMC and the second btr unit by it self
      • Bessnet
        • May 2016
        • 5
        I have tried changing fromt door interlock switch and all drum motors including black developer motor assembly\
        same problem
