WC 7545 poor copy quality
  • KMtech69
    • 68
    Hi All
    I'm working on a Workcentre 7545 that I replaced the black developer and the first 3 prints looked great. Then I ran a printer calibration and the blacks went back to the same way they looked before I replaced it. I have not worked on a lot of xerox machines. I have included the first 4 prints out of the machine. any help would be appreciated.
    Thank you in advanced.
  • AjitN
    • Mar 2009
    • 287
    Re: WC 7545 poor copy quality
    [QUOTE=KMtech69;707248]Hi All
    I think degrading of CQ is right from second page but as you mentioned there is huge difference from 3rd to 4th print.
    Check / Clean developer gears, and all bias / Charge contacts
    Hope this helps
    • Flash
      • 378
      Remove the transfer belt and clean the transfer roller for the black.
      • Richard.Xerox
        • Jun 2015
        • 73
        I've seen this before, bad K toner. Was a new K toner installed recently?
        Remove K toner and vacuum out the dispenser assembly, remove K dev tank and vac out or replace tank, new dev.
        Bad K toner is blocking the trimmer bar on the K dev tank, if you print a K solid fill long edge feed it will probably look stripy across the page all the way from top to bottom.
        Don't put that K toner back in that machine or any other, install a new K toner after completing the above.
        • rockdude
          • Feb 2011
          • 257
          Richard from Xerox is correct.
          But instead of bad toner, I stongly suspect "Generic / Compatible" toner which causes the same symptoms.
          But fix is the same start vacuuming and dont put crap toner in machine!
          • Detonation
            • Feb 2010
            • 403
            Check dispenser pipe assembly and dispenser motor assembly.
