Xerox 5855 Jam In Print Engine - Error persists after clearing
  • jsolo
    • 21
    [Jamming] Xerox 5855 Jam In Print Engine - Error persists after clearing
    I'm new to the Xerox 5855. Got a paper jam this AM, cleared the jam but the machine won't clear the error. Fault codes are 383.190.00, 310.101.00, and 310,120.00. Tried cycling power, checked the paper trays. Would really appreciate some help.
  • eunuch39
    • Aug 2014
    • 40
    Re: Xerox 5855 Jam In Print Engine - Error persists after clearing
    make sure to check duplex tray for jam as well as inverter exit sensor
    • jsolo
      • 21
      Duplex tray is clear. Not sure where the inverter sensor is located. is it the optical sensor in the duplexer? That one's clear.
      • jsolo
        • 21
        Found and fixed the issue. Thanks for pointing me to the right area!
