Xerox ColorQube 9303 Error: 093-533
  • rockdude
    • Feb 2011
    • 257
    I have a service request for a Xerox ColorQube 9303 with Error: 093-533 on the display.
    The customer is approximately 100 miles away from me, so I am trying to decide whether to take the call or not.
    The customer claims they moved the machine while doing some remodeling, and the error code came up soon after.
    Edoc says that the Black reservoir on the print head is not filling within expected time.
    She also says that she had to put 4 or 5 ink sticks in the black inkloader, which she never had to do before.
    I suspect I may be looking at a ink spill inside the machine.
    I don't do a lot of work on these (I have never had to replace a printhead) mainly just the Main Belt, Software updates, a few broken plastic parts.
    Just was looking for some guidance before I travel 100 miles and have no chance of repair.
    Any help would be appreciated.
    Thanks in advance.
  • prismtech
    • May 2014
    • 199
    Re: Xerox ColorQube 9303 Error: 093-533
    Thanks in advance.
    93-533 is a rare code to have on a colorqube 92xx / 93xx. Go to your spare parts machine and pull out the complete ink conveyor system. With the distance the client is away, I would also bring a spare marking unit complete.
    The only part that usually goes bad on the conveyor is the pulley that spins the travel belts. Not usually a move related issue. Symptom will be the ink won't travel down the holes anymore.
    Sent from my SM-T530NU using Tapatalk
    • prismtech
      • May 2014
      • 199
      Thanks in advance.
      P.s. 93-533 is black ink melter is heating to slowly. Did you give the right code? That one is not reservoir related.
      • rockdude
        • Feb 2011
        • 257
        Re: Xerox ColorQube 9303 Error: 093-553
        I apologize to all who viewed the correct code is 093-553.
        Sorry about that guys, my fingers and eyes betrayed me.
        • Richard.Xerox
          • Jun 2015
          • 73
          Printhead not filling in time.
          I've had a few of these recently, always resolved by replacing printhead gaskets and the reservoir.
          If you replace reservoir don't forget to power up into IME diagnostics and run dc976 to re-prime the ink delivery system. Before that make sure you've seated the umbilicals corerctly, hard to recover if all the ink in the reservior leaks away
          • rockdude
            • Feb 2011
            • 257
            Will try, Thank You for your reply.
            • prismtech
              • May 2014
              • 199
              I don't field service a 093-553 failure. It'll break your heart.
              The solution is to take another fully tested and functional marking unit and swap out the ColorQube-bomb.
              What will happen if you try to do it onsite is an ink leak explosion. Once a used ColorQube print head is pulled you have at best a 50/50 chance of having it reseal. The end result is you will fix the no-fill issue only to have it yak out ink EVERYWHERE.
              At a 100 miles out i would personally take a entire replacement unit with me (the entire machine). You are probably going to open the the unit up to find about another 8 things ready to fail. From the drum drive belt to the stripper assembly to the horizontal paper path top flap and on and on and on and on. Even brand new from the factory, 92xx / 93xx ColorQubes were full of broken bits. Dreadful machines.
              • prismtech
                • May 2014
                • 199
                I literally have 20 used 93xx / 92xx colorqubes on hand for parts at any time.
                We have about 12 left out in the field we have to service.
                I will use ALL OF THE 20 MACHINES for parts in 6 months.
                That is how quick the pieces of s**t fail.
                • rockdude
                  • Feb 2011
                  • 257
                  Thanks for your input "prismtech".
                  I already swapped it out for a WS7845, and everything is good agian.
                  Thanks again for replying.
                  • prismtech
                    • May 2014
                    • 199
                    That was the right move.
                    • Detonation
                      • Feb 2010
                      • 410
                      Such a shame Xerox built them so badly. I've always loved solid ink, but have the feeling nothing ever really improved (to put it mildly) in terms of reliability since the Tektronix Phasers.
                      • Richard.Xerox
                        • Jun 2015
                        • 73
                        They're built really well compared to their laser office boxes (compare the feel and finish to a WC78XX or WC59XX, those boxes feel cheap and nasty by comparison) Just a few quirks with CQ92/93.
                        If they made the umbilicals with non air permeable tubing that would be half the battle over with, no more air ingress. Also uprate the reservior solenoids and those 2 things would pretty much cure the ink delivery faults.
                        Solid ink is Xerox' highest margin product so i imagine it will be back at some point when they have worked out the kinks and cheapened it up some more, unless of course they move page-wide inkjet over from the Brenva line and start using it in the office (HP already do this with an A4 MFP)
