xerox 7755 dc 252 toner dust problem
  • DheerajBE
    • Feb 2018
    • 39
    [CQ] xerox 7755 dc 252 toner dust problem
    Dear All,
    whenever we try to change drum. blades and pcr for Xerox 7755 and dc252 series. after changing compatible drum, pcr drum blade when we print many times we get bad print quality from machine looks like the toner sparking all over the print.
    pls help
    www.viagrasansordonnancefr.com viagra france ordonnance
    Re: xerox 7755 dc 252 toner dust problem
    Originally posted by DheerajBE
    Dear All,
    pls help
    sparking? do you mean SPECKLING?
    did you powder the drum n blade when assembling?
    what about the charge unit?
    compatible drum... my guess compatible toner also?
    did you CLEAN the machine?
    did you follow the init procedures in the manual?
    any error codes?
    pictures of the problem prints?
    • DheerajBE
      • Feb 2018
      • 39
      any error codes?
      yes my customer is using powder toner and compatible drums, pcr and blade,
      here is the picture of the defect.
      pls suggest some rectification, its major problem for all machines
      vertical lines not big issue im just worried about the sparking like dots all over the print
      • mickey singh
        • May 2014
        • 93
        Check bottom drum seal myler, and it could also be compatible toner causing the issue!
          [ATTACH=CONFIG]41044[/ATTACH][ATTACH=CONFIG]41045[/ATTACH]
          not powered TONER....
          when putting the drum unit together... use a DRUM powder to DUST the drums and turn them before installing... powder the BLADE also -= NOT the PCR=- compat toner n drums could also be the issue
