xerox 5655 communication failure
  • walidcharifi
    • Feb 2011
    • 379
    after installing a new system software on 5655 with flash disk (Altboot)
    - display incomplete phase install
    - fuser and drum not compatible
    - foreign interface device (fid) is not detected
    Re: xerox WC 5655 Altboot
    is it the right firmware?
    what problems caused you to reload?
    you had a hiccup somewhere .. did you try again?
    • walidcharifi
      • Feb 2011
      • 379
      I download firmware a Xerox site
      25.54.53.000
        Re: xerox 5655 communication failure
        25.54.53.000
        "A" Xerox site or OFFICIAL site?
        did you look on list and make sure it was for your unit?
        right files put in ALTBOOT?
        • walidcharifi
          • Feb 2011
          • 379
          The battery nvm is dead .... After 03 months I reload software !!!!!!!
          • walidcharifi
            • Feb 2011
            • 379
            Yes in official Xerox site
            5655 SBC controler
            • walidcharifi
              • Feb 2011
              • 379
              Page de configuration before failed
              https://drive.google.com/folderview?id=1dLhsEdC9Lyn6u6oKtfdjh5j6M6fQuSRe
              • xcopytech
                • Aug 2006
                • 1786
                Replace software module not only yellow battery
                  Google Drive: Sign-in
                  WE DON'T HAVE PERMISSION to view it...
                  if you knew it is a NVR battery CHANGE THE DAMN BATTERY!?
                  IT seems you aren't a tech.. you would have done that... HIRE A QUALI'D TECH!
                  • walidcharifi
                    • Feb 2011
                    • 379
                    thanks
                    • walidcharifi
                      • Feb 2011
                      • 379
                      [QUOTE=Phil B.;713219]WE DON'T HAVE PERMISSION to view it...
                      IT seems you aren't a tech.. you would have done that... HIRE A QUALI'D TECH![/QUOTE
                      ]Desktop
                      • shaahin
                        • Jun 2017
                        • 26
                        Hi
                        for incomplete phase install go to 131 chain 3 and change 2 row install phase and dc install phase from 0 to 4.then restart .
                        For fuser incompatible set the correct region in dc131 chain 3 . 0 for 110 volts and 5 for 220 volts
                        • walidcharifi
                          • Feb 2011
                          • 379
                          Originally posted by shaahin
                          Hi
                          thanks
                          and for foreinge interface device FID is not detected
                            [QUOTE=walidcharifi;713307]
                            ]Desktop
                            so? i knew it wasnt a Xerox site you got it from.... did you unpack the files before putting on USB drive?
                            • walidcharifi
                              • Feb 2011
                              • 379
                              https://www.support.xerox.com/support/workcentre-5645-5655/file-download/enin.html?operatingSystem=winxp&fileLanguage=en_GB &contentId=102480&from=downloads&viewArchived=fals e
