Xerox DocuColor 242 (DC250 series) light banding black
  • Detonation
    • Feb 2010
    • 395
    I have a DocuColor 242 that's showing significant banding OB side in black only. I suspected bad drum-developer contact or a bad developer housing, but this doesn't seem to be the case. I have done the following:
    • replaced developer
    • replaced black drum
    • replaced the entire drum drawer with one from a good machine
    • cleaned ROS
    • replaced ROS
    • replaced 1st BTR
    • replaced entire ITB unit
    • replaced MCU
    • replaced charge (K) preclean HVPS
    • replaced developer bias (K) HVPS
    • replaced ROS flat cables
    Some more things I could think of are NVM PWB, Power Unit, IOT driver PWB and flat cables between MCU PWB and IOT driver PWB. But honestly I'm getting a bit desperate and I'm also short on time. So I'd like to avoid a (further) wild goose chase and see if there's any suggestions here!
    Attached is a full halftone 80% K. C, M and Y look good.
  • Detonation
    • Feb 2010
    • 395
    Re: Xerox DocuColor 242 (DC250 series) light banding black
    SOLVED: 2nd BTR turned out to be te problem. Can't get my head around why it only failed with black, but there it is.
    • i495979
      • Oct 2023
      • 1
      2btr change did not help for me. But K-drumunit change helped for awhile. So I suspect corotron or discharge string oxidized contacts on machine side.
