Xerox wokcentre 5875, Activation code request
  • newdente.gianluca
    • Feb 2016
    • 58
    Hi, i resetted the machine for service reason and now i have this message displayed:
    A supplies plan activation code must be entered soon.
    Can someone help me? i havo no experience with xerox brand. Thank you.
    Re: Xerox wokcentre 5875, Activation code request
    what do you mean by: i resetted the machine for service reason
    did you wipe the NVR or reset to factory defaults?
    do you have the manual?
    are you a tech?
    what was the service reason?
    • newdente.gianluca
      • Feb 2016
      • 58
      Hi, i have no manual, i wiped the NVR instead of dactory settings, i did a mistake, can you hel me? yes i am a tech but i have experience with kyocera, canon, toshiba ando no experience with xerox.
        so you DON'T work on Xerox... you have NO Manual ... and you went poking around? nope no help from me.... you NEED to have a manual when working on Xerox...
        from now on ..STICK WITH MACHINES YOU HAVE MANUALS AND KNOWLEDGE OF.
        • newdente.gianluca
          • Feb 2016
          • 58
          so if you dont wont to help me why you spend time for replay..accusing... me insted of helping me, you dont wont to share you knowledge but you signed up in a big forum. Every one of us can make mistakes.
            Pointing out you are NOT equipped to handle this shit... I have been in this industry for 31+ years.. I would NEVER go to a call so poorly equipped for it.
            • Detonation
              • Feb 2010
              • 404
              The activation code is needed to use the 'metered' supplies that Xerox only gives to customers with maintenance contracts.
              Can't help you with an activation code, but I think you should be able to switch to 'sold' supplies instead, which are the regular supplies you can buy online. But I don't have much experience on the 58xx machines, so can't tell you if this will really work.
              • rockdude
                • Feb 2011
                • 257
                Odin is correct, probably looking for code for metered supplies.
                But you have to understand the point Phil B. is making.
                The Xerox machines without service manuals are almost impossible to properly work on.
                Even if you are an excellent Copier / Printer Technician, the codes, tests, and procedures for even the simplest repairs are necessary and only found in the manuals.
                Xerox has gone to great lengths so that these manuals are not readily available in a PDF format to the public. Only in EDOC.
                If you want to start working on Xerox equipment you really need to invest in a Laptop such as the one "XTRAIN" has.
                His laptop has the basic EDOC (Electronic Documentation) that you will need. Then it's just a matter of getting individual modules for the machines you will be working on.
                You still will need to be a half way decent service tech, but at least with the manuals you will be able to follow the advice given in this forum.
                Hope you understand.
                  I guess sometimes I do come off as 'brash'... but WHEN I was coming up ( not only in this industry ) PC *politically correct* was NOT something we adhered to.. People today are too often BUTT HURT.. sorry don't really care.
                  Yes YOU SHOULD NOT *as an unseasoned tech* go to a XEROX call without a MANUAL like RockDude said you WILL need the manual. (newer models REQUIRE PWS and EDOC) You can turn a Xerox ( really ANY machine ) into a BRICK if you DO NOT KNOW WhiskeyTangoFoxtrot what you are doing.
                  • raheel
                    please
                    • iftikhar muhammad
                      • Sep 2020
                      • 7
                      i have service manual of xerox wc 5875 i will send you if you need.you should install firware .
                      • weetu
                        • Jun 2020
                        • 12
                        Originally posted by raheel
                        please
                        Sorry to say, but after working with XEROX machines for 40 years I have to tell you that even us, trained service technicians, have to make a call to Support Centre. Then they will calculate a new PIN for the machine.
                        If you are not a certified technician they can't help you.
                        That's the way it goes.
                        • yousaf
                          • Jun 2010
                          • 43
                          send me sr# so i will send u activation code
                          • decentrobin
                            • Oct 2021
                            • 2
                            I have Workcentre 5330 and Serial Number is 3322804929. Could you please generate the code and share it?
                            • Housseyn
                              • Nov 2020
                              • 10
                              Whatsapp +21383163815
                              Email mediavision13000@gmail.com
