ITB Home Position sensor and ITB belt (7232)
  • yomba
    • Jul 2012
    • 37
    Back again: Those any one know where i can buy the ITB and ITB home position sensor for xerox 7232 ?
    Please...Thanks
  • JrTech
    • Jun 2013
    • 217
    Re: ITB Home Position sensor and ITB belt (7232)
    001R00610 IBT Assembly. This will come with Belt Home Sensor as that is on the frame. This sensor is on the upper left hand side of belt assembly if you are looking at it as if it were in the machine. There is a shiny silver patch on the underside of the belt. This patch on the belt is read by a little spring action sensor and when the silver patch comes in contact with sensor it says Hey I'm Home.
    I would not recommend you purchase just the belt for self installation as you DO NOT have very much room to put these on. If you are Tech savvy and want to try it. Be very careful when putting the tension roller back in and remember the silver patch must go on back side.
    If you Google Xerox 001R00610 you can purchase pretty much anywhere on the web. If you are US based there are a few companies that offer these in a rebuilt / re - manufactured and brand new. There is a company called Parts Drop in New Jersey that carries both versions of the assembly
    Hope this helps
    • Detonation
      • Feb 2010
      • 404
      001R00610 is the belt for the 7120/7220 series, NOT the 7232.
      The patches usually fix the problem on the 7232. Part number is 604K45000 or 604K45001. The patches for the DC250 family also work.
      The ITB itself and ITB home sensor don't break often. I have a home sensor if you need one. The belt and belt assembly are hard to get nowadays, these are old machines...
      • workcentre7232
        • Feb 2024
        • 6
        What do you mean by; The patches usually fix the problem on the 7232.
        What's a patch?
        I'm getting that error 089-311 turning it on and off is getting old hoping a cleaning will fix it.
        Also looking for the service manual.
        Thanks, Kelly
        • hnami
          service technician
          • Nov 2023
          • 168
          Ibt belt is very Sensitive to facing the front mirror inside the belt. From the service menu, you can drag the belt up and down so that the reflector is in front of the sensor.
          • Detonation
            • Feb 2010
            • 404
            What's a patch?
            Thanks, Kelly
            There is a reflective patch (square shiny sticker) on the belt that passes a sensor. When the patch is damaged or the sensor is dirty, you will get this error. Since the patch is on the outside of the ITB for this model, it is easy to check if it is ok. Often the glue lets go, then it is best to just remove the patch and glue residue, and replace with a new patch.
            • hnami
              service technician
              • Nov 2023
              • 168
              When the belt move to up or down reflector com out of position and you shod adjust it
              • Detonation
                • Feb 2010
                • 404
                As far as I know there is no way to adjust the belt on the 7232.
                It is pretty common for the sensor to become dirty, as it is, inconveniently enough, located under the belt.
                • workcentre7232
                  • Feb 2024
                  • 6
                  Thanks for the response, I took it all apart and cleaned it but no luck that patch is scratched.
                  I found a replacement patch on part drop I may try that before buying a new belt.
                  I'm temped to cut a piece of aluminum tape and covering the damaged patch with it, maybe I'll luck out and it will word.
                  Thanks Again!
                  • workcentre7232
                    • Feb 2024
                    • 6
                    The patch fixed it.
                    Just wanted to pass that along in case someone else is having the same issue.
                    Thanks for the advice.
