WorkCenter 7835 will not Altboot
  • LamsterPaul
    • May 2014
    • 46
    • 22801
    Re: WorkCenter 7835 will not Altboot
    you need the PWS.. the laptop.. you cannot get just the software
    • LamsterPaul
      • May 2014
      • 46
      • Detonation
        • Feb 2010
        • 392
        Wouldn't you connect the PWS via USB as well? In my experience it should just work with USB Altboot. Triple check USB stick is correct and try another USB drive as well. Plug directly onto SBC (on side of machine).
        • adriansto
          • 2369
          You need special cable 600T02332 for connect the laptop to machine sbc board.
          The pws tool works on Win7 32 bit, I dont know if it works on WinXP but you dont need to have pws software for altboot tool to work.
          The 600T02332 cable is somehow like cable used by you on ColorQube 93xx machine.
          The machine have old controller or new ConnectKey controller ?
          There are different dlm files for 30-35 machine than for 45-55 maqchine.
          • LamsterPaul
            • May 2014
            • 46
            • MrXerox
              • Sep 2010
              • 76
              If it is just failing because the usb security then all you need is an admin password reset to then go in and enable them. If that does not work just post exactly what screen it fails on and what the 7 segment led reads and we can go from there.
              PM me the serial and total meter and i can get you reset key for admin password.
              • Richard.Xerox
                • Jun 2015
                • 73
                Simpler solution, replacing the SD card will unlock the USB ports.
                • LamsterPaul
                  • May 2014
                  • 46
                  After reset the Admin password and deactivate the USB security on front and back USB, now i had make and Altboot over USB, and all works fine, also NTFS-Usb formatted works well
                  thanks for helping !
                  • Detonation
                    • Feb 2010
                    • 392
                    I haven't figured out a way to reset the admin password without Altboot just yet...Can someone enlighten me?
                    • adriansto
                      • 2369
                      There is software application.
                      Enter the machine serial number and total meter and the software generate 12 digit code.
                      This code will be input into machine special menu and reset the admin passwd to default.
                      • he7060
                        • Jul 2015
                        • 14
                        1- enter diagnostic mode >> hold "0" for 10s then press Start >> password 6789
                        2- tab on Adjustments then tab on dc301 NVM initialization >> choose Copier >> Copy Controller>>select All >> then initialize.
                        3- tab on Call Closeout then Exit & Reboot.
                        4- after the machine turned on you find it in a Non Customer Mode.
                        5- again enter diagnostic mode again >> hold "0" for 10s then press Start >> password 6789
                        6- tab on Adjustments then tab on dc131 NVM Read/Write > enter 616-014 >> change the value to 2
                        7- again tab on Close >>Call Closeout then Exit & Reboot.
                        8- while the machine is turning choose customer then follow the setup as you want till reach to Lock or Unlock Tools >> choose Unlock Tools.
                        9- you will never need the admin password again to login to the web page.
                        Kaywords: xerox 7835 admin password problem, 7225, 7845, 7856, 7830, 7820, login problem, xerox workcentre 7545 default admin password not working, xerox password reset, xerox workcentre 7545 default password problem
                        • Detonation
                          • Feb 2010
                          • 392
                          I'm not sure I'd recommend initialising NVM for this purpose, you'd lose a lot of setting. But changing NVM for the system install phase is an interesting idea.
                          • Perfix Solutions
                            • Feb 2020
                            • 5
                            Paul,
                            Try in this order;
                            1) USB port on the IP board 2) Try a different USB ThumbDrive (smaller the better) 3) Double check your filing structure is correct and that your files have NO file extentions. I also think the USB has to be formated in FAT not FAT32.
                            Good Luck!
                            • Caffeine
                              • 389
                              Many better options have been provided already, but just as general information, you DON'T USE a PWS laptop on this machine for AltBoot. You just use a simple USB stick, formatted correctly, with the software on it.
                              The machines you mentioned which you did AltBoot on (3535 and 9301) are ancient, nothing is done that way anymore. It isn't even possible.
                              All Xerox WorkCentre models from the last 10 years are the procedure below. You just get the latest software (DLM) from the Xerox website. (The regular Xerox customer website.)
                              For the WC78xx machines:
                              Forced Altboot Upgrade Process
                              Requirements
                              - Must use a USB thumb drive with at least 300MB of free space.
                              - The DLM file must be in a folder named Altboot at the root level of the USB drive while ensuring that you DO NOT have a folder called Upgrade at the root of the USB drive.
                              - Within the Altboot folder on the USB thumb drive a file named FORCED_UPGRADE (case sensitive with no file extension) must be included.
                              Procedure
                              1. Power down the WorkCentre.
                              2. While the power is off insert the correctly configured USB thumb drive into the USB slot at the front of the machine.
                              3. Power on the machine and within minutes, the local UI will display the message “Machine NOT Available” and “Please wait... Services are being retrieved”.
                              4. Soon after this, the Upgrade Interface window will be displayed on the WorkCentre’s User Interface, showing the upgrade progress of all relevant modules.
                              5. After the upgrade has completed the network controller will initialize, and after a delay it will automatically print a Configuration Report, and reconnect to the network.
                              6. The device is ready for use.
