WC7120 has error 093-320
  • axyun
    • Aug 2007
    • 1323
    Customer called with fault 093-320 on wc7120. I see that it refers to develper unit drive motor.for collor units. Is it usually one of the drum units
    casing the problem and is it best to swap one at a time until error does not appear? I believe this customer has units in stock in machine area. Frank
  • Detonation
    • Feb 2010
    • 411
    Re: WC7120 has error 093-320
    If you put clean gloves on you can try to rotate the drums by hand, usually it's very obvious which one is stuck. Could potentially save you 2 drums.
    • axyun
      • Aug 2007
      • 1323
      Thanks Detonation. Sounds like a good plan. Frank
