Xerox Docucolor 240 Printing yellow shadow / colour off register ??
  • mrbutcha
    My docucolor 240 has developed a problem a few days ago, where anything i print whether it be full colour or mono theres a yellow shadow as if the yellow is off register, as you can see in attached pictureprint.jpg
    i have been across forums for a few days and tried the following -
    swapped colour drums
    new black drum
    new charge corotron
    cleaned ros glass
    ran belt edge learn diagnostic
    ran registration cycles in diagnostics
    all to no avail
    has anyone got any other idea ?
    would be greatly appreciated
  • Enzo
    • Jul 2009
    • 413
    Re: Xerox Docucolor 240 Printing yellow shadow / colour off register ??
    I had the same problem with xerox dc12. It is caused by ibt
    • mrbutcha
      Hi Was is the ibt cleaner or belt?
      • Enzo
        • Jul 2009
        • 413
        On the ibt there was a silver patch. I do not know if on the ibt of 240 there is the silver patch. I think no. Surely some other forum friend can help you.
          Originally posted by mrbutcha
          Hi, My docucolor 240 has developed a problem a few days ago, where anything i print whether it be full colour or mono theres a yellow shadow as if the yellow is off register, as you can see in attached picture[ATTACH=CONFIG]41565[/ATTACH]
          new black drum
          new charge corotron
          cleaned ros glass
          all to no avail
          has anyone got any other idea ? would be greatly appreciated
          good start.. you will need a PWS i'm sure for this tho... manual adjustments (UGHHHHH) of the laser beams coming from EACH ROS.. ( kinda like my Ex.. tons-o-fun and can also be messy) start by stripping all fuser/belt/drums/toners.. clean internals .. then remove the shield and clean out ROS area... reassemble run test ( still the same) then run manual ROS adjust. if you aren't a calm type person.. maybe hire a certified tech.
          was a real PIA in the older printer/copier series.. and knowing Xerox they have screwed da pooch again!
          Good Luck!
            OP stated:
            new black drum
            new charge corotron
            cleaned ros glass
            all to no avail
