WC7845....Where's the Scan
  • blackdog
    • Jun 2012
    • 211
    Hi to all you Xerox Wizard's,
    Scan to Shared Folder on WC7845 fails each Scan.
    Folder remains empty.
    WC7545 at same location same Network works fine.
    Customers IT Dept cannot seem to get the Scan to Shared Folder
    on WC7845 working???
    Anyone have a solution or Scan to Shared folder Update
    they could email me??
    Thanks in advance...
  • blackdog
    • Jun 2012
    • 211
    Re: WC7845....Where's the Scan
    Has no Xerox Tech Configured Scan to a Shared Folder?
    • rockdude
      • Feb 2011
      • 257
      Please post Config Page.
      Most of the time it's because nobody has put a name in the address book.
      There MUST be at least one name in address book to scan.
      If you have one already in there, post Config Page.
        • 30238
        Since it's there IT all setting the same? ie user name password path? check the domain setting Windows doesn't play well with others outside it's network
          1st... you didn't provide ANY information regarding how it was setup!
          2nd.. 1st post 10 hours ago.. not ALL of us live on CTN.
          3rd.. did you follow the instructions in the manual.
          4th.. what was the EXACT message you get when it fails.
          Want help ... provide valuable information for diagnosis!
          • blackdog
            • Jun 2012
            • 211
            Gentleman thanks for your input.
            Phil, As I stated customers IT dept configured Scan to Shared Folder on both boxes in the exact same fashion.
            WC7545 works fine but WC7845 will Scan to same folder but folder remains empty.
            There are no error codes and no failures. IT said Scan is working but the for some reason never gets to folder...
            I will forward a Config Pg later.
            Again thanks to all....
            • Detonation
              • Feb 2010
              • 410
              What firmware level do you have on the 7845?
              • rockdude
                • Feb 2011
                • 257
                This sound like a port or packet blocking on your customers firewall.
                There are different versions of security software on each of the Xerox Workcentre Machines.
                Example: If the firewall is excepting packet security 2.0 and the 7845 has packet security 2.5 the firewall my not
                recognize the higher version and block the packets from going through to the folder.
                Sometimes Xerox will provide a special firmware upgrade that will pass the firewall specs / sometimes they don't.
                Talk to the customers IT people and see if they have a Physical (Sonicwall, Watchguard, etc..) or a Software firewall (Jupiter, Barracuda, etc..) and how it's setup to handle packets.
                • lmartinez323
                  • Feb 2019
                  • 5
                  enable smb1 on programs and features try that
                    REALLY?
                    have you NOT kept up with the problems w/ SMB1 and the REASON Microsoft has disabled it?
                    Does your boss approve of you doing this?
                    Does he have good lawyers on staff/call?
                    IF you enable SMB1 and it allows a VIRUS or MALWARE into the server/network and that Virus/Malware does infectious DAMAGE to said system... he can be in for a MAJOR law suit and you would be looking for another job.. and IF word gets out WHY you were let go... well repeat after me... " Would you like fries with that order Ma'am/Sir?"
                    very poor advise.
                    • blackdog
                      • Jun 2012
                      • 211
                      REALLY?
                      very poor advise.
                      Thanks Phil I am always seeking good advise..
                      Customers IT Dept has tried getting some answers direct from Xerox Support but still in this
                      day and age Xerox will only confide in the chosen few.
                      • chubblies
                        • Jun 2011
                        • 155
                        Check the unc path of the scan location to ensure it is not dropping the scan in a higher level. If you are not getting any errors or a failed scan sheet printing then the scan must be going somewhere. I would clone the working ones and put onto this machine to see what happens then, just obviously change the IP to the correct one
                          • 30238
                          • rosaro75
                            • Mar 2009
                            • 87
                            REALLY?
                            very poor advise.
                            for 78xx series if you upgrade to 73.0100.75.34540 this version have port 445 . this one no need to activate smb1.0. and also using mailbox (public or private mail box) by enabling mail box option safe and can access from any pc also any mobile phone too.
                              So you are also saying use smb1? Do you know the risks?
