DC 242 toner
  • chrisio
    • Jul 2012
    • 104
    DC 242 toner
    Ok. I made the mistake of using a compatible yellow toner when I couldn't get hold of a genuine toner and I have ruined the drum I can actually see little hard particles stuck on the cleaning blade that have scored the charge roller. I have a genuine toner in there now and about 70% used.
    My question is how long does it take for the toner to work through the dev so if I put a new drum in I'm not going to ruin that one as well or would I be better off replacing the dev powder as well?
    Cheers
    Chris
  • Caffeine
    • 391
    Re: DC 242 toner
    Cheers
    Chris
    Definitely better off replacing the developer powder with a fresh load. Even if you flush the toner through, the old generic developer would still be in there lingering for quite a while longer and it is more likely to do damage to your drum than the toner.
    Cleaning out the assembly and replacing the developer is a messy nuisance, but it is the best way. Be thorough. A LOT of developer clings to the back side of the mag roller even when you rotate it, and you want to get it all off. A fresh packet of developer isn't terribly expensive. Less than a color drum, which may die early because of the residual generic materials.
    Since you've already used 30% of a genuine cartridge (right?) the generic is already out of the dispenser and the transport tubes. So nothing to worry about there.
    • chrisio
      • Jul 2012
      • 104
      Re: DC 242 toner
      Thanks. I thought as much. I have flushed 70% of an original toner through now. I will get another drum and a pack of dev and swap it all out.
      Lesson learned that it's more expensive to run the machine on compatible toner.
      Cheers
      Chris.
