Xerox 700 D C P - 10-342
  • greg thomsen
    • Dec 2018
    • 5
    [Error Code] Xerox 700 D C P - 10-342
    I have a xerox 700, giving error code 10-342. It supposedly means Decurler Cam Upper operation failure is detected.
    I've unplugged / turned off all parts of the machine including high capacity feeder, booklet maker etc.... and have checked for any paper jams.
    I have followed the advice in an older thread on these boards. I have vacuumed the toner, cleaned the gears, and oiled the shafts, and the decurler drive couplers in the inside back, I had to take apart the right side of the copier to reach them. I still have 10-342 fault code. What else could I try to get my 700 working again? Do i have to replace the decurler drive? is it a motor of some sort? or the decurler itself?
