Poor toner fixing on transparencies - WC 7545
+ More Options
Posts
  • AjitN
    • Mar 2009
    • 287
    [CQ] Poor toner fixing on transparencies - WC 7545
    Team
    I have problem of poor toner fixing on transparencies when printed on WC 7545.
    Settings are Tray 5 manual bypass with paper type transparency.
    If I move the fingers over prints OR lightly rub, toner does't flick. If rub vigorously OR nailed toner comes out.
    I tried another paper types, which does not work as machine does not detect paper ( optical sensors ) & gets jammed.
    Customer makes customized presentation items for corporate clients and need to take lot of prints on transparencies.
    me know the
    Has anybody faced similar problem? Is it possible to increase fuser temperature for transparency only. If so please let me know the NVM locations?
    Thanks in advance & regards
  • Caffeine
    • 390
    Re: Poor toner fixing on transparencies - WC 7545
    Originally posted by AjitN
    Team
    me know the
    Very common, unfortunately. Transparencies can be tricky. Even if the brand you are using says it should be fine (even if it is Xerox brand) you may need to experiment with a few different brand transparencies. You SHOULD be able to find one that works acceptably. That's how I've always had to solve transparency issues, is just try different ones until I get one that does ok. Usually thinner ones.
    As far as I know, others will hopefully chime in, there is no want to increase the temperature by way of NVM adjustments on the 75xx models.
    • AjitN
      • Mar 2009
      • 287
      [QUOTE=Caffeine;741996]Very common, unfortunately.
      Thank you for your quick response.
      These transparencies are working OK with Ricoh MPC 2011.
      Is it possible that this media will work better (Fusing aspect) in low speed machines (7525)? Since all the components are same ( Toner, Developer, IBT, Even fixing except speed) lower speed machines will get more time to fix the toner in to the transparencies.
      Ricoh 2011 is 20 CPM & have same belt and roller combination in fuser. That's why I thought of lower speed. Hopefully it will work.
      Regards
      • Caffeine
        • 390
        [QUOTE=AjitN;742124]
        Regards
        Very possible, but it depends on if they lower the fuser temperature even more in the slower machines. Or is could depend on the actual speed of the paper traveling through the fuser. Some machines, to differentiate between the various speed models, don't actually change the speed of paper travel, they just leave larger or shorter "gaps" between sheets to achieve that model's speed. In that case, the actual paper travel speed isn't any different.
        Also, the 2011 is, if I'm not mistaken, a more traditional temperature fuser machine (ie, high temp), whereas the WC 75xx are low-temp machines.
        Good luck!
        K
        • AjitN
          • Mar 2009
          • 287
          [QUOTE=Caffeine;742126]
          K
          YES this is a very nice explanation, it makes sense. Timing between two feeds can be controlled easily. But paper output from exit assy. shows difference in the speed. Low speed machine throws out paper slower than high speed machine.
          I will check again & get back
          Regards
