Print Face Up Xerox 4112
  • costou
    • Sep 2009
    • 44
    I have two Xerox 4112 CP.
    I can't send a print Job with face up... i can do it in copy mode.
    I don't understand i have used all off drivers model.
    With my old Xerox 4110 it was possible.
    some help please !!!!
    Re: Print Face Up Xerox 4112
    Originally posted by costou
    Hi, I have two Xerox 4112 CP.
    With my old Xerox 4110 it was possible. some help please !!!!
    look in your print driver... look for "output"or "finishing" tab..should be in there.
    • costou
      • Sep 2009
      • 44
      Thanks for amswer,
      i looked everywhere.... No tab Finishing or Output.
      I tried PS and PCL Drivers
      I also Tried 4110 drivers with face up option but still printing face down
        Thanks for amswer,
        Ok do you know how to enter admin mode thru the remote user interface? RUI from there you can do just about anything
        • costou
          • Sep 2009
          • 44
          Directly by the printer screen or the web interface ?
          Tell me the way to go
          thanks
          • costou
            • Sep 2009
            • 44
            Any NVM to change ?
            • SeniorTch
              • Jun 2017
              • 117
              Have you tried This ?
              • costou
                • Sep 2009
                • 44
                [ATTACH=CONFIG]42278[/ATTACH]
                Yes i tried, but print face down.
                Maybe i have to reload software or firmware
                Software Version :
                Version 1.211.1
                • Caffeine
                  • 391
                  Software Version :
                  Version 1.211.1
                  Some of the drivers don't show the option for Face Up printing. That screenshot shows that you're using the PCL driver, and I don't know what features it might be excluding.
                  On many Xerox machines, the Face Up option is in the Advanced (catch-all) last tab. What do you have available in that tab?
                  • costou
                    • Sep 2009
                    • 44
                    You're right, normaly face up option is in The advanced Tab.
                    I checked with PCL an PS driver and Not.
                    I installed Xerox 4110 PS drivers for test.
                    The Face up option appear in Advanced Tab but print in face down.....
                    Strange.... No ? with Two printer 4112....
                    • Caffeine
                      • 391
                      You may be out of luck then, unfortunately... The 4110 and 4112/4127 speak a SLIGHTLY different language (assuming you're using the built-in Green controller on both) which is why the 4110 drivers didn't work. They would work for most things, but not all.
                      But re-installing the software, on either the printer or on the computer, won't change the options in the driver. (Assuming it is the same version.) It might fix it if it was there but didn't work, but if it doesn't even show up in the driver at ALL... Well, that's that.
                      Of course if you put a Fiery on the 4112 you can do Face Up, but us like using a sledgehammer to kill a mosquito.
                      • adriansto
                        • 2392
                        There is workaround fix for this problem but it involve to do some steps.
                        First create mailbox - see the machine Administrator Guide.
                        Then print and in machine PCL6 print driver select mailbox number as paper output.
                        From machine select Mailbox you printed in. Select the print job in mailbox and change settings/print - output orientation.
                        • costou
                          • Sep 2009
                          • 44
                          THANKSSSSSS
                          I will test it this week-end and with a bit of luck it will work.
                          I come back to you quickly.
