XEROX 5890i hard drive replacement
  • vmx12
    • Sep 2007
    • 55
    [Misc] XEROX 5890i hard drive replacement
    The copier had a blank screen on boot up. Installed a new hard drive and same thing. When powering up it goes thru the usual boot up but the screen remains white (blank). Stumped.
  • xcopytech
    • Aug 2006
    • 1792
    Re: XEROX 5890i hard drive replacement
    Did you check SD card?
      SD and then altboot
      • kashif
        • Apr 2013
        • 45
        SD and then altboot
        first you should install firmware (altboot) then check SD card
          ummm IF the SD is bad it won't take altboot
          just as if the card was not present
          • kashif
            • Apr 2013
            • 45
            yes dear you are right but i am just suggesting him before change SD try from the altboot, one time i was faced same problem in xerox 5890 and i was format HDD and reinstalled altboot.
              Drop the dear...
              • vmx12
                • Sep 2007
                • 55
                plugged in a thumb drive with the firmware, did nothing, still have a blank screen
                • xcopytech
                  • Aug 2006
                  • 1792
                  Check, replace SD card
                    was the thumbdrive clean?
                    altboot <DIR>?
                    alboot files inside the DIR?*not reg firmware SPECIAL*
                    if any of them aren't right you cannot upload via alt boot
                    **you did have machine off.. Thumb inserted THE Power on right?
                      won't do anything if incorrect files on drive .... no altboot DIR
                      and FAT32 4gig format
                      • xcopytech
                        • Aug 2006
                        • 1792
                        There is a small led display on the rear side of machine.
                        What code you have on the display?
                        • vmx12
                          • Sep 2007
                          • 55
                          there is a 2 on the display
                          checked the thumb drive files, all correct
                          • xcopytech
                            • Aug 2006
                            • 1792
                            2 is error for system memory
                            5 is for sd card
                            • vmx12
                              • Sep 2007
                              • 55
                              5 is for sd card
                              replaced the memory, got rid of that code, now I have an 8! apparently I am going to run all the numbers one by one.
