XEROX 5890i hard drive replacement
  • xcopytech
    • Aug 2006
    • 1794
    #16
    Re: XEROX 5890i hard drive replacement
    8 is also for SD card.
    Have many 58xx machines with white screen and new sd card always was a solution.
    • chubblies
      • Jun 2011
      • 155
      #17
      If you have another 5890 create an image of the SD card and put it on a decent SD card, then try again with the altboot.
      Also try a forced altboot rather than a normal one, as this will overwrite every firmware slot regardless whereas a normal altboot will not update everything.
      To do this create a folder called 'altboot' within that folder load the firmware file, and also the 2x extracted files from the below zip file
      Dropbox - Xerox.zip
