FX CM415 fuser replacement
+ More Options
Posts
  • biggsy
    • Nov 2011
    • 5
    [Misc] FX CM415 fuser replacement
    Hi Guys, we have a FX CM415 that was telling us the fuser unit needed replacing soon, ordered a brand new fuser (and transfer unit) and replaced both. The machine is now telling us to replace the fuser unit - how do we clear this message - machine is working fine - customer doesn't like the message!.
    Any help will be greatly appreciated.
    Nigel
    Re: FX CM415 fuser replacement
    Originally posted by biggsy
    Hi Guys, we have a FX CM415 that was telling us the fuser unit needed replacing soon, ordered a brand new fuser (and transfer unit) and replaced both. The machine is now telling us to replace the fuser unit - how do we clear this message - machine is working fine - customer doesn't like the message!. Any help will be greatly appreciated. Nigel
    didn't turn it off before replacing parts... did ya?
    • biggsy
      • Nov 2011
      • 5
      Hi Phil,
      Thanks for your reply.
      One of our techs did this job so I can't say whether he turned it off first but I suspect he didn't - I did ask him that as a hunch and he was vague. Is there another way to reset this?
      Cheers
      Nigel
        Hi Phil,
        Cheers
        Nigel
        Not completely sure.. might have to jumper the fuse on chip or replace chip..
        If bought from Xerox approved parts..
        Fudge it.. send it back.. they are pretty good on FOC replacement..
        Where did you purchase from?
        When trying to get RMA ...
        BE SURE TO CHECK SM FOR PROPER REPLACEMENT PROCEDURE......
        and stat that clearly in rma report.
        Good luck
        • elsab
          • Dec 2007
          • 63
          Reset HFSI 950-800
