Xerox Workcentre 7655 error "System fault, contact administrator"
  • wmoussa
    • Feb 2019
    • 38
    I have a Xerox Workcentre 7655 who stopped working, and shows error "System fault, contact administrator" , no fault numbers or anything else
    the problem started a couple of weeks ago, rebooting it was the solution to get it it to work for a few days , now rebooting it won't do, it goes straight to that error mood. Scanning is the only service available, printing and copying are not.
    I tried replacing the fuser, as I remember I had this a few years ago with another Xerox and replacing the fuser solved the matter.
    I don't have the PWS, anything else I can try besides the fuser? do I need to rest anything ?
    Thankful for any help.
  • adriansto
    • 2387
    Re: Xerox Workcentre 7655 error "System fault, contact administrator"
    Try to reseat flat cable from ROS to MCU pwb.
    Also disconnect the network cable and restart the machine.
    It's a good ideea to have pws diagnostic software for this machine to check error codes.
    • xcopytech
      • Aug 2006
      • 1794
      Enter in diagnostic and check fault history.
      Check for 042-326 code.
      • wmoussa
        • Feb 2019
        • 38
        Yes I see that error 42.326.00
        and also 20.331.00
        • xcopytech
          • Aug 2006
          • 1794
          20.331 missing fax card
          42.326 ibt belt home position
          • wmoussa
            • Feb 2019
            • 38
            So I replaced the transfer belt assembly unit with another working printer, so now I get another error "The finisher is not available, contact system administrator"
            I recall that the printer encountered a power outage in the middle of a printing job, was printing something, could that maybe have missed up many things?
            now, checking the fault history I get error code 20.331 plus the 12.335
            • wmoussa
              • Feb 2019
              • 38
              current errors in the attached pics,
              also previous ones
              • xcopytech
                • Aug 2006
                • 1794
                12-335 communication between finisher pwb and booklet pwb.
                • wmoussa
                  • Feb 2019
                  • 38
                  looks like something wrong with the finisher yes, another finisher is working with the same printer.
                  What went bad with the finisher ? any idea?
