Xerox dc240 - fault - image Offsetting - Is there an NVM adjustment to up Fuser Temp?
  • Jedi Ben
    Senior Engineer
    • 77
    We Have a customer with a issue on a red letterhead type banner on Red offsetting / ghosting down the page. He has replaced the fuser unit and tried different paper stocks and it still does it. the paper used is just 120 gram.
    I know on Ricoh in service mode i can adjust the fuser running temperature by 10-20 degrees and was wondering if there is a way off doing this on a Xerox? possibly by adjusting an NVM? all colour calibration ect is fine.
    Any help on this would be great!!!
    Ben
  • Caffeine
    • 390
    Re: Xerox dc240 - fault - image Offsetting - Is there an NVM adjustment to up Fuser T
    Ben
    There isn't an easy way to do that. You can use "Gloss Mode" but that cuts the speed in half. Selecting a heavier weight of paper will also cut the speed.
    Genuine toner has in my experience never caused offsetting. Be certain they're not cheaping out and using some generic. None of the generics work properly. They just don't.
    • Jedi Ben
      Senior Engineer
      • 77
      I have asked if it has been run on compatible toner? he said it has in the past so there,s the problem as its not doing it on any other colour. the machine is not on a contract so i have advised the only way to solve this problem is a new dev tank, dev, brand new toner and vac out the toner dispenser.
      thanks
      ben
