DC242 over toning on black
+ More Options
Posts
  • chrisio
    • Jul 2012
    • 104
    Hi.
    My dc242 is leaving a slight scattering of black toner over the entire sheet of paper- its so slight that when I scan the image its not picked up but if you hold the sheet next to a unprinted sheet you can see the difference.
    The black drum is recent (82% remaining) , the black dev is recent (within 20k pages), I have checked the values for toner density and according to the service manual they are well within tolerance, the ATC sensor values look correct.
    Any idea where I go from here?
    CHris
  • InterfaceP
    • Jun 2013
    • 488
    Re: DC242 over toning on black
    Probably the K BIAS PWB. Its located on the left side under the panel where the UI attaches.
    • chrisio
      • Jul 2012
      • 104
      Thanks. Where in the service manual does it refer to this? Nothing comes up when searching for it.
      Cheers
      • InterfaceP
        • Jun 2013
        • 488
        Cheers
        PL 11.2 Item 2
        • chrisio
          • Jul 2012
          • 104
          Thanks.
          Is this the board https://www.iteminconline.com/105k20...loper-bias.htm
          Is there any tests I can do or is it a case of swap it out and hope its correct.
          • chrisio
            • Jul 2012
            • 104
            I have the new board coming in the next day or so. Is it just a case of swapping the board and all my troubles will be resolved ir do I need to set it up?
            Chris
