Error code 042-326
  • positiveg
    • Jun 2018
    • 299
    Error code 042-326
    Hi there guys iv'e had this issue past few days
    Now we just installed a new IBT belt like a few months ago
    Last one we had lasted about 98 months
    I know there's a way to reset the NVM just trying to get some assistance on what's the value I should use to bring it up to rest it please thanks
    G
  • InterfaceP
    • Jun 2013
    • 488
    Re: Error code 042-326
    The search bar is a real thing.
    • positiveg
      • Jun 2018
      • 299
      As real as trying it several times before writing this thread, Real.
      • dschultz31
        • Aug 2018
        • 33
        Xerox Docucolor 250 shows fault code 042-326 but freezes when repair is attempted
        • positiveg
          • Jun 2018
          • 299
          Thanks no luck
          We replaced the belt cleaned the entire IBT unit still no luck
          The system still has the error and you don't get the error you'll get if the unit starts with the door open
          so it's like it isn't even booting up properly
          the copy print option is unavailable though.
          • xcopytech
            • Aug 2006
            • 1794
            What machine you talking about?
            DC250
            C550
            DCP700
            • positiveg
              • Jun 2018
              • 299
              DC250
              C550
              DCP700
              C75 press
              • xcopytech
                • Aug 2006
                • 1794
                C75 do not have same NVM for belt home reset.
                Do yu have a service manual?
                • positiveg
                  • Jun 2018
                  • 299
                  Yeah but not in there.
                    i find that hard to believe... one thing Xerox was anal about.. was including those type procedures in the SM
                    • positiveg
                      • Jun 2018
                      • 299
                      I'll take a look again. I'm wondering if the issue might be the belt not being set properly on the unit.
                      Also after use does it ever shift slightly? Cause I'm wondering what happened to the old one.
                      Dropbox - 2019-06-29 13.15.05.jpg - Simplify your life
                      • InterfaceP
                        • Jun 2013
                        • 488
                        NVM reset for Fault 042-326 is 741-132
                        Fault 042-327 has no NVM reset its a non damaging Fault.
                        Little Video I made many moon's ago, pay attention to the reflective patch (1:53) and the sensor (2:28)
                        YouTube
                        • positiveg
                          • Jun 2018
                          • 299
                          YouTube
                          Thanks reset the NVM again after making sure the belt was in there properly and the error went away, didn't know had to reset the the NVM again after the change.
                          • positiveg
                            • Jun 2018
                            • 299
                            YouTube
                            Wait that's you. I looked at that video (have looked at it in the past too) but last night i looked at it before I adjusted the belt to make sure that it was done properly then I placed it back in, but I didn't know had to again reset the NVM
                            Thanks bro video worked to make sure wasn't touching the sensor etc.
                            Now if you can assist with the jamming I'm having in the duplex unit lol
                            • knightfall
                              • Jul 2006
                              • 633
                              I just checked, its listed in there. Follow the directions and you should be golden. Just remember to clean both sensor,.
                              Get your facts first, and then you can distort them as much as you please.
