Xerox ColorQube 8570 error code and reboot on reboot
  • GIUBOSS
    • 1385
    [Error Code] Xerox ColorQube 8570 error code and reboot on reboot
    greetings, the code on the display is: printer error:
    91.720,00: 6895 and restarts continuously
    I tried to raise the printheads but nothing strange. sometimes he prints the cleaning pages and even the test prints but now he is nailed to the error, I had already changed the cleaning blade 3 years ago. Thanks for the help
  • OMG
    • May 2016
    • 31
    Re: Xerox ColorQube 8570 error code and reboot on reboot
    Printhead tilt error. Printhead not moving from back to front like it should. The common causes are a broken head tilt gear, wax spilt in machine and got on printhead shaft block and hardened so now head want tilt. Could be printhead tilt gear drive assy or process drive assy.
    • GIUBOSS
      • 1385
      thanks to the information, tomorrow I will try to control the fault.
      • rockdude
        • Feb 2011
        • 257
        Bring a process drive, and a D.M. Camshaft. (Check for cracked out of postion cam)
        Make sure you re-time machine. Before installing process drive.
        (also don't forget to remove timing pins from process drive before turning on machine)
