Xerox color 560 yellow missing
  • mshabban
    • Jan 2017
    • 101
    Hello all, am having a challenge with a 560 which intermittely loses yellow ,i have reseat the ros cables ,ckeand the ros ,exchanged developer tanks but all in vain ,any help will be much appreciated.
  • adriansto
    • 2392
    Re: Xerox color 560 yellow missing
    What about drum module , bias contact on developer module , btr1 from IBT assy ?
    • mkdirs
      • Oct 2014
      • 177
      i think that you have yellow Dev gearbox broken
      Xerotk.com
      xerox copier technician
      • chubblies
        • Jun 2011
        • 155
        Check the drum gearbox, swap it with another colour and see if the fault follows
        • mshabban
          • Jan 2017
          • 101
          Thanks guys for all the support ,much appreciated
          • mshabban
            • Jan 2017
            • 101
            Thanks guys ,but u know i have changed the developer tanks module assembly with all drums in but all in vain,i have also changed the yellow drum motor ,and the power supply but still all in vain
