Machine not booting
  • tomson25
    • 104
    [Error Code] Machine not booting
    Xerox WC7225 machine not booting ,How can I reinstall system software,If anybody have installation procedure please share it with me,I am new in this xerox machine.
  • bhasucbe
    • Jul 2019
    • 9
    Re: Machine not booting
    Firstly you must diagnose the reason for not booting.
    Check the LCD Display near to the network port if its U means you can reinstall the software.
    The software can be downloaded from xerox support website and format 16gb pen drive and create a new folder called Altboot and extract the software file (dlm extension only).
    Insert the pen drive to front usb or rear usb port and restart the printer.
    • tomson25
      • 104
      Thanks for the support.In the site there is manual reinstall and auto.Which one to down load ?
      • bhasucbe
        • Jul 2019
        • 9
        you need to download manual software. Auto is used to upgrade the device.
        • copier tech
          • 8144
          Hi,
          Create a firmware boot USB pen drive if your HDD is ok this should get the Xerox working again,
          PM me should you need the firmware etc,
          Firmware Update - Printer & Copier Firmware
          • tomson25
            • 104
            Hi,
            Do you have XEROX firmware
            • bhasucbe
              • Jul 2019
              • 9
              WorkCentre 7220/7225 File Download
              download manual upgrade file
              • tomson25
                • 104
                In manual upgrade there are so many files all needs to copy in altboot folder?
                • bhasucbe
                  • Jul 2019
                  • 9
                  [ATTACH=CONFIG]43203[/ATTACH]
                  Since the machine is totally down you can use 073.xxx ending with 34540.dlm file only inside altboot folder.
                  power off the device and insert the pen drive in front usb port. Power on the device and it will take 45 min approximately to load the software.
                  • tomson25
                    • 104
                    Thanks for the support,
                    While installing this firmware at end getting Software upgrade error.
