Colorqube 9301 Error 94-534
  • prismtech
    • May 2014
    • 199
    #16
    Re: Colorqube 9301 Error 94-534
    Sorry to just reply to this right now... could of saved you alot of trouble.
    The colorqube 93xx and 92xx chronically have trouble with "drum belt" slippage. You can replace all the related parts and still have it occur every other print on some machines.
    Easy solution... Take the belt tension spring and mount it 1" further up the lever. When you close it from now on it will over tension the spring fixing the slip error. I have performed this on dozens of belt slipping colorqubes and have had a 100% fix rate.
    To demonstrate how effective it is, just take the drum motor in both hands and twist it tighter while printing. If it's a machine that is always having this issue that alone will fix it while you are holding. The spring re-mount is the permanent fix version of doing this.
    Sent from my SM-T530NU using Tapatalk
    • prismtech
      • May 2014
      • 199
      #17
      P.s. almost all 3b jams are the drum slip message. Over tension the spring and you fix the problem.
      • LamsterPaul
        • May 2014
        • 46
        #18
        thanks, Colorqube Nr. 1 will work now (rear bearing was fault)
        now the second Colorqube have the same problem, but with the front bearing make some noise
        we had now an new C8035 with support plan, hope he is better
        • prismtech
          • May 2014
          • 199
          #19
          I've never had the bearings go.... even on machines with 5 million impressions.
          Increase the spring tension via moving the lever mount point... problem solved.
          This of course will only fix drum slip jams or ratio jams, which is 99% of them. Check your error log for the jam code.
          People always assume it's related to the stripper blade or the transfix stripper blade because it jams at 3b. But it never usually is unless the stripper gate mount rod has broken in two.
          • prismtech
            • May 2014
            • 199
            #20
            The front drum encoder wheel and sensor gets blamed alot as well... and I've never seen one actually fail.
            • LamsterPaul
              • May 2014
              • 46
              #21
              sensor look ok, at drum rotation, you hear a lound nois from front bearing,
              at my other CQ, you feal a resistant when turning the real drum bearing, before it was replaced, now he works again
              • prismtech
                • May 2014
                • 199
                #22
                First time for everything!
