Colorqube 9301 Error 94-534
  • LamsterPaul
    • May 2014
    • 46
    [Dead] Colorqube 9301 Error 94-534
  • bhasucbe
    • Jul 2019
    • 9
    Re: Colorqube 9301 Error 94-534
    Its mainly due to drum slipping and if you have replaced the belt for worn out. It could be debris issue only clean the drum pully & drum motor pulley thoroughly with alcohol.
    The fault code appears after main motor starts rotation or after some time. Check transfix roller binding also.
    • LamsterPaul
      • May 2014
      • 46
      Cleaned the drive with brake-cleaner, but with no success, maybe I replace him, with an Altalink or Versalink 8035
      I spend very much each year, to keep the 2 CQ9301 running, allways problems with umically pipes and printheads
      • Richard.Xerox
        • Jun 2015
        • 73
        Take the new belt off and check it, some new belts are coming through still covered in release agent.
        Pinch the belt together and try to rub one side past the other, if it slips the belt needs cleaning, dump in hot water with washing up liquid and scrub the grooves with a nail brush, rinse in clean hot water and let dry. Now should be much less slippery.
        • LamsterPaul
          • May 2014
          • 46
          thanks, I will try it, it got am second new belt in stock and I will try to mount this
          Paul
          • LamsterPaul
            • May 2014
            • 46
            • adriansto
              • 2386
              Drum drive motor, drum driver pwb, defective rear bearing - PL94.20 item 3 = 020K20552
              Before replace pulley check T30 screw holding pulley to the drum.
              • LamsterPaul
                • May 2014
                • 46
                THANKS
                I try to use the Diagnostic mode with Drum,
                when I remove the Tranfix Roller at the Test, it will past the test,
                If I install it, it will fail, I think is was the Problem, because there are some INK rests still on the Drum from the before Printout, that failed,
                I try to remove it, with no really success,t
                then it was possible to print 2 pages, before it fault again,
                QUOTE=adriansto;791270]Drum drive motor, drum driver pwb, defective rear bearing - PL94.20 item 3 = 020K20552
                Before replace pulley check T30 screw holding pulley to the drum.[/QUOTE]
                • LamsterPaul
                  • May 2014
                  • 46
                  • adriansto
                    • 2386
                    This error is from SBC CPU fan
                    • LamsterPaul
                      • May 2014
                      • 46
                      thanks
                      could this the problem ? For the drum Also ?
                      CPU fun for the Mainboard in the Drawer in the back ?
                      • LamsterPaul
                        • May 2014
                        • 46
                        What you think over an DC 250? i can get one cheap, I think, its the best solution,
                        mayme I will remove the rear bearing and check it, but first I need the right tool for it
                        • chubblies
                          • Jun 2011
                          • 154
                          Check front and rear transfix bearing mounts for cracks, as the uneven pressure can cause binding of the motor. Does the motor attempt to run at all? I have had the main PSU cause the same error.
                          These machines should be scrapped, they are troublemakers and will always cause you issues. Don't be surprised if you need heard too as the debris from the belt will find its way into the resevoir and can get into the ink feed lines in the umbilical.
                          • LamsterPaul
                            • May 2014
                            • 46
                            I Need to remove the complete drum to check it,
                            so it Needs some time,
                            before the Problem are started, I heard a lound noise from the back side at 3B, like an bearing or somethink, but then the noise are gone
                            • LamsterPaul
                              • May 2014
                              • 46
                              It works again, the fault was the rear Bearings looks like it was the fault, now he works again,
                              I had replace the Pully with the Bearing,
                              but too late, we had order a new AltaLink c8035
