xerox versant 80 error 099-339
  • levyk
    • May 2019
    • 12
    [Error Code] xerox versant 80 error 099-339
    hi all,
    having this error 099-339 Fuser Belt in Limit Fail i moved it back to position and it keeps on happening again mainly when i use 20lb paper i tried a new fuser but the problem continued, would anyone be able to specify why this is happening and what the solution? tnx much
    levy
    Re: xerox versant 80 error 099-339
    Originally posted by levyk
    hi all,
    levy
    not sure .. but are there "nip" adjustment screws on that fuser? if so did you follow the procedure in the manual
    • levyk
      • May 2019
      • 12
      i dont really know where the nip screw is located will look into that, ill advise if anything changes
      tnx phil
      • adriansto
        • 2387
        There are a lot of possible causes for this error ( gears, sensors, etc ) but noting to do with fuser nip adjustments.
        You need service manual and follow the proper procedure from there.
          Originally posted by adriansto
          There are a lot of possible causes for this error ( Ggars, sensors, etc ) but noting to do with fuser nip adjustments.
          Well to be honest, I did say I wasn't sure on this model. But thanks for correcting me.
          • levyk
            • May 2019
            • 12
            hi tnx for your reply, in the service Manuel it just says "Fuser Belt Assembly is out of position. Reseat the assembly and make sure the Belt Edge Sensor is in contact with thebelt edge" so i keep doing this and it keeps on happening again, trying to figure out the cause and how to solve (am i looking at the wrong manual?)
            tnx
            • adriansto
              • 2387
              There are more.
              Pdf service manual 705P01362 & edoc 705P01379
              • levyk
                • May 2019
                • 12
                There are more.
                where can i get this manual?
                tnx
                • adriansto
                  • 2387
                  tnx
                  stoadis@gmail.com
                  • Dech
                    • Aug 2014
                    • 48
                    try this
                    see attachment
                    • levyk
                      • May 2019
                      • 12
                      Originally posted by Dech
                      try this
                      see attachment
                      tnx dech
                      it was already fixed, thats exactly what was happening!
                      tnx
                      • rowaner2002
                        • May 2021
                        • 6
                        hi all,
                        levy
                          reread the thread it is explained in there
                          this really isn't an end user fix
                          • levyk
                            • May 2019
                            • 12
                            hi this could happen a few problems ill attach a few solving let me know if it was helpful17.pdf13_Fuser fault 099-399.pdf12_Fuser Belt fault code 99-339.pdf
                            • robdemos
                              • May 2023
                              • 1
                              Hello here, just wanted to say thanks because even in 2023 this holds up and can happen also on a versant 2100.
                              Solution works like charm.
