Problem with Xerox Workcenter 7225i
  • michaelw23
    • Jun 2025
    [Misc] Problem with Xerox Workcenter 7225i
    I have a Xerox Workcenter 7225i, the problem is as follows.
    Problem with ADF .
    Whenever i place document\s in the ADF, a message something like that is prompted
    Please choose the flatbed or the ADF to continue. We cannot use the ADF
    When i remove the document , this message is no longer displayed.
    Question :- I think that the sensor is still good because the ADf can detect my documents but still why does the system asking to make a choice.
    Is there a configuration setting to set it Auto as ADF sense paper. Or is there a problem with the ADF.
    Problem with printing
    We have three computers printing to that Xerox printer on the network , we have installed the latest printer driver .
    We have notice that very seldom , if we print to the printer , no documents come out of the printer. We have to restart the printer ( Cold boot) and then documents are printed
    Your help and advise would be most appreciated.
  • howling
    • Feb 2019
    • 35
    Re: Problem with Xerox Workcenter 7225i
    make sure there is no ip conflict...when your printing problem occurs turn off your machine and ping it if it responds then you have a ip conflict...seen this a lot
    • jhalfhide
      • Apr 2015
      • 451
      The adf / glass issue is the sensor that detects the lid being up/down. You can usually get away with taping a penny or similar, over the area where the black plunger hits so that it activates sooner.
      The official fix is a hinge repair mod kit
      Sent from my LYA-L09 using Tapatalk
      • BaconSteve
        • Apr 2019
        • 140
        • shinchan
          • May 2011
          • 195
          hi. can you please post a picture of that hinge repair mod kit?
          I'm curious and would like to know more about that repair/mod kit for the left hinge I presume
          • jhalfhide
            • Apr 2015
            • 451
            I won't be back at my laptop to find the Edoc bulletin until the weekend but basically it's as follows.
            The hinge is too strong and the plastic too thin so you get warping and cracking. The only sign initially is the error about originals and then with extended continued usage you will see the cracking.
            The innovator kit contains metal brackets, bolts, screws and a drill bit which goes on your screwdriver. You drill the plastic and attach the metal plates to strengthen the hinge surrounds.
            Will post the innovator part no when I can but it's worth ordering just for the screwdriver drill bit they send you, which has helped me since with countless field bodges
            • shinchan
              • May 2011
              • 195
              all right. i'm having the same problem too. okay. i will wait for your edoc bulletin. thank you
              • rockdude
                • Feb 2011
                • 257
                There are a Right & Left Repair Kit Mods.
                I have posted both.
                • hobbele
                  • Nov 2019
                  • 38
                  Don't use this Repair Kit, just do what jhalfhide says ;-)
                  It's the best and easiest way to repair it.
                  Just press the back left on the DADF before doing anything. So you can easily test if it works.
                  • jhalfhide
                    • Apr 2015
                    • 451
                    We do that most of the time now but if they're heavy glass users, the hinge eventually goes. We've done 2 machines with the full repair kit. The rest have a small square of thick car numberplate tape on them
                    • Jack79
                      • Jul 2014
                      • 312
                      I just stick something under scanner lid to let activate the sensor.
