Xerox phaser 7800 print defect
  • toadman
    • Nov 2019
    • 7
    hi there
    I have a customer using a Xerox phaesr 7800 who is getting print defects on cyan and yellow.
    Image drums are all ok.
    Xerox have been out and changed the cyan and yellow developer and blamed the compatible toner.
    print defects have returned very quickly on the cyan.
    cleaning the machine/led lasers etc does not help.
    printing on card stock (Xerox approved for the printer)
    any ideas what causes this defect?
    Re: Xerox phaser 7800 print defect
    Originally posted by toadman
    hi there
    [ATTACH=CONFIG]44122[/ATTACH]
    [ATTACH=CONFIG]44121[/ATTACH]
    it looks like toner clumps have created the problem.
    are they still using generic?
    are they shaking the toner cart the proper way/amount of time?
    I haven't found ANY generic toners that play well in color Xerox units... most mono's are acceptable tho.
    take a business cards.. slip it between the doctor blade and the mag roller... run it the full length of the dev roller.. back n forth a few times..
    reinstall and test.. if it remains please provide better quality pics (my old eyes)
    if fixed, it is toner clumps in the dev unit. You SHOULD be able to remove the dev and take cover of.. using a fine screen sifter.. sift the powders breaking up any clumps.. return powder to dev unit.. reinstall and test.
    (clumps in toner = not properly shaken or toner has been stored in a high heat area and has started to melt together)
    • toadman
      • Nov 2019
      • 7
      Hi PhilB, thanks so much for taking the time to reply to both my posts.
      I actually have 2 clients with problems with these machines so I thought i would keep the issues seperate.
      For the print defect above we sent out a 3rd party engineer to visit. He concluded that the developer unit had a fault that could not be cleaned and Xerox replaced this with a new cyan developer but the defect has returned.
      The 3rd party engineer reported that he has seen the same defect on printers using OEM toners and that cyan toner could not be at fault as the defect was very obv and toner does not have the ability to create such a defect as shown (if toner was the issue it would have defects all over the page). He believed something else is causing the damage to the developer.
      I think we should we go back to him with your info? id love to get to the bottom of this.
      Im attaching some more defect images.
      original defect before replacing cyan developer
      (on the above they also had a defective M drum)
      new defects after replacing the cyan developer
      thanks for any advice !
        [ATTACH=CONFIG]44137[/ATTACH]
        [ATTACH=CONFIG]44138[/ATTACH]
        [ATTACH=CONFIG]44139[/ATTACH]
        I have been a Xerox trained tech since 1998. I have NEVER seen a genuine Xerox toner due that UNLESS it was stored in high heat for a long time. Crap toners do it becase they can't use exact formulations.
        If you have read others threads, crap toners are about 80% (conservatively speaking) of quality problems reported.
        Crap toners also tear up fusers, drums,belts plus the dev units
        My 2 cents
        • toadman
          • Nov 2019
          • 7
          Thanks Phil, appreciate your advice.
          • toadman
            • Nov 2019
            • 7
            Hi Phil, sorry me again. Ive gone back to the toner manufacturer who are being quite helpful but they have said that if the toner was the issue it wouldnt not happen at only one spot on the dev roller. It would be clumping and damaging the roller along its length. Have you seen this before?
            I would really like to get to the bottom of it !
            cheers
              cheers
              ok I ASSume you talked to their sales guy?
              bad toner can cause buildup on a mag roller... sometimes in spots.. sometimes the whole mag roller.
              yes it does cause leaks - clumps.
              years ago on mono machines it could clump..scratch/score the mag. and when that happens you get build-up and dumps.
              not sure who you are using... but on Xerox I try to steer my customers away from compat.. some are hard headed and they pay the price.
              • howling
                • Feb 2019
                • 35
                yep...phil is the hokage plus there is no such thing as compatible in xerox...its either genuine or fake....
                and i love the look on some customers who tried installing "compatible" the look on their faces is priceless esp. when they sees the bill
                Xerox trained since 2007
                  Hokage? I trained in 98 and YES there are compatible toners out there for sale:
                  Xerox - Page 1 - Supplies Outlet
                  NOW tell me again how there are NO COMPATIBLES!?
                  • tsbservice
                    Field tech
                    • 8020
                    It's easy, check if lines appear on mag roll. If not problem is Not in Developer unit.
                    Otherwise as Xerox techs replaced devs, why not get them back to check their work?
                    Those lines look like exactly what Phil described but if developer is replaced and unit is cleaned properly it should be some very shi** compatible toner to cause this again shortly after service.
                    May be wrong, Not Xerox trained at all.
                    • howling
                      • Feb 2019
                      • 35
                      it means a master...and i still think there is no such thing as compatible, only fake and genuine (less headache for genuine and more for the fakes).
                        WTF are you talking about "Master"? clearly your thinking is skewed.. They are advertised ( if you even opened the fucking page I linked to) as compatible.... they even have COMPATIBLE drums.....
                        clearly your terminology in your shithole country is different than the REST OF THE WORLD'S terminology...
                        maybe you'll recognize THIS terminology:
                        FUCK OFF
                        WANK OFF
                        LOSER
                        STFU....
                        get the point asshole?
                        • howling
                          • Feb 2019
                          • 35
                          ohhhk i was just complimenting you as i dont have that kind of experience like you do ok ...but clearly you are off your meds
                          im outta here have a nice day.
                          And
                          Fuck you too take your meds regularly so your not grumpy.
                            And
                            hey jackass I take no meds and my doctor says " You are the most logical/sane person I have met "
                            yes I am grumpy when dealing with total losers/assholes...
                            you lend nothing to the site and frankly IMHO you are also worthless as a human...
                            maybe in your shithole cuntry you are something... but here in the USA you would be nothing but a social welfare case... and our congress and states are full of them so WE DON'T NEED YOU HERE.
                            Hava great day loser.
                            • Lance15
                              • Jun 2015
                              • 1089
                              Red cards say a lot here on CTN........for a reason.
                              But, there are COMPATIBLES and GENUINE. COMPATIBLES meant they will WORK.....just not HOW WELL.
