copy option not available
  • Reeves
    • Apr 2012
    • 296
    [Error Code] copy option not available
    I have a problem with my xerox 550. As it start up it shows the following error code 061-328.
    Neither of the copying menu or the network menu are available.sometimes am getting the error code 062-360
    I would be grateful if you can help.
    Thank you.
  • Detonation
    • Feb 2010
    • 410
    Re: copy option not available
    062-360 is a problem with the copy unit (carriage position problem). 061-328 is a problem between C ROS and MCU PWB. Can be either ROS, or flat cables, or MCU PWB.
