Xerox 5845 error drum and fuser
+ More Options
Posts
  • TOTO
    • Sep 2019
    • 21
    Hi I have an used xerox 5845 .power up and work good until the sector elictricity shot down. When I start up again boot up normal. And show message drum and fuser incompatible .
    There is a solution. Thinks
  • xeroxsharp
    • Nov 2008
    • 270
    Re: Xerox 5845 error drum and fuser
    Yes it is. Job for serviceman.
      first have a certified Electrical Tech check the problem.
      power issues can mess with copiers big time.
      then hire a trained Xerox Tech to fix your issues. I can tell you right now, once you tell the tech what happened, he will tell you to get power fixed first.
      • TOTO
        • Sep 2019
        • 21
        Hi everyone I resolve the problem with the nvm restored
        The machine restart and it s ok
        Thinks
